12-30-2014, 11:52 PM | #1 |
What transmission cooler?
I've decided to go with a dedicated transmission oil cooler. I have a 450HP SBC with a TH400 trans. I've narrowed it down to these two coolers. One is a Hayden and the other is a B&M Following are links to both. Thanks in advance for any help! If anyone has a recommendation othe that these two coolers, I'm willing to listen.
http://www.monstertransmission.com/H...34_p_4894.html http://www.bmracing.com/products/702...&md=&smd=&eng= |
12-31-2014, 12:03 AM | #2 |
Re: What transmission cooler?
B&M cooler is very well built plus accommodates AN fittings if you choose to plumb it. Its an exact copy of the OEM one I replaced in my 97 Silverado but larger. The Hayden is not as efficient due to the design compared to the stacked plate type like the B&M. The stacked plate type designs are used in general aviation as engine oil coolers. I bought mine through Summit racing with free shipping.
12-31-2014, 12:15 AM | #3 |
I have a B&M also on my 4.3 truck because of the recommendations on various forums for the same reason joe states, the stacked plates is very efficient, all that outside surface area in contact with the fluid and can cool the fluid in a large desired temperature change. the hayden fin type is more efficient used in vapor cycle systems where the system undergoes a state change (fluid to gas) in a very narrow desired temperature change or with a very large fluid cooler like a radiator.
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
12-31-2014, 12:31 AM | #4 |
450hp and a automatic setup, you will be creating some oil temperatures cruising the town
12-31-2014, 09:58 AM | #5 |
Who Me?
I have the B&M style on my RV and works great. I don't think the other one will be as efficient.
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
12-31-2014, 07:53 PM | #6 |
Never Ending Projects
The plate style (the B&M one) is the best style and you will find them on many OEM applications. They run cooler and I have been using them for decades.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
12-31-2014, 08:03 PM | #7 |
Much appreciate all the replys. I was leaning toward the B&M before posting this. Now, after the input from here, the B&M is the one I'm going with. Thanks again!
01-20-2016, 07:58 PM | #8 |
But Found Her 25yrs Later!
I bought this one.
Just got it installed, but haven't ran the truck yet. Amazon.com: B&M 70268 SuperCooler Automatic...
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
01-20-2016, 11:49 PM | #9 | |
The link doesn't work for me. |
01-20-2016, 11:52 PM | #10 |
I thought I'd chime in with what has worked well for me.
Hayden bar and plate 679. Good luck
Build Threads: "JED" 66 GMC C1000 http://inliners.org/ubbthreads/ubbth...1857#Post61857 "Cropwell" 66 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=587639 |
01-21-2016, 12:05 PM | #11 |
Moderator
If you have air Conditioning do you nount it in front of the Air Con Condenser?
01-21-2016, 12:54 PM | #12 |
Yes, you do.
01-21-2016, 01:59 PM | #13 |
'65 chevy lover, Where are you thinking about mounting it? I've got a hayden style cooler for my TH400, but being that large, the only real spot I can mount it is right behind the grille.
2013 Malibu LTZ 1996 C1500 4.3/5spd 2wd |
01-21-2016, 02:05 PM | #14 |
Moderator
Are you guys running it through the Radiator first, then the Air Cooled Cooler?
01-21-2016, 02:48 PM | #15 |
01-23-2016, 02:58 PM | #16 |
Moderator
So what do you think?
01-23-2016, 03:02 PM | #17 |
I don't have a radiator with a transmission cooler. I'm using the B&M independently.
