Old 12-18-2013, 10:46 AM   #1
Leverhead
64 C10 Pinion Angle
Setting up a C10 with a 12 bolt...stock trailing arm suspension. How is the pinion angle adjusted on these trucks? Are there shims available? Seems like I need to get the pinion down a bit. Thanks.
Leverhead is offline   Reply With Quote
Old 12-18-2013, 04:19 PM   #2
Leverhead
Re: 64 C10 Pinion Angle
Com'on guys...nobody here has ever adjusted their pinion angle? No info anywhere? Anyone?
Old 12-18-2013, 04:58 PM   #3
1963c-10
1963c-10's Avatar
I don't know personally, but does this help any? There was a good thread on the 67-72 side about pinions awhile back...might be worth a shot.
http://67-72chevytrucks.com/vboard/s...d.php?t=543726
Are you lowering the truck? I believe they are supposed to be 2-3*
1964 Short bed trailer
Old 12-18-2013, 05:08 PM   #4
1963c-10
1963c-10's Avatar
Pinion angle shims
http://www.classicperform.com/Store/...k/6072RPS1.htm
Old 12-18-2013, 11:17 PM   #5
Leverhead
Thanks for the replies. Looking at the pic above, I'm trying to get to the 2nd illustration ... seems i'm at the 3rd right now. Looking for shims specific to these trucks and their trailing arms...I'll check with CPP and see if those will work....otherwise.....????
Old 12-19-2013, 02:03 AM   #6
Captainfab
60-66 Nut
A vendor that sells circle track parts should have the shims for the trailing arms. Try Speedway Motors.
Captainfab is online now   Reply With Quote
Old 12-19-2013, 11:30 AM   #7
Leverhead
Thanks...will do. I'll post my findings.
Old 12-19-2013, 06:22 PM   #8
Leverhead
Seems like the ones from CPP are the way to go..ordered a pair of 3 deg shims..I'll post the results when I get them in. Thanks all.
Old 12-19-2013, 06:38 PM   #9
tincan1966
tincan1966's Avatar
What is your transmission angle? How much difference is there?
From personal experience, I will highly recommend not guessing at what it needs.
tincan1966 is offline   Reply With Quote
Old 12-19-2013, 07:35 PM   #10
Leverhead
No guessing here....trans output shaft is 3 down and diff pinion is 6 up. My concern was finding the correct shims...3 should get me where i need to be at the current ride height.
Old 12-29-2013, 06:41 PM   #11
Leverhead
Update: Got the shims and they are in (CPP part# 6072RPS-3 - pics attached).....looking much better now. Thanks for the replies...much appreciated.
Old 12-29-2013, 08:22 PM   #12
Rich 5150 69
Rich 5150 69's Avatar
Note; you actually want a three degee downward tilt at the nose of the third member, during cruise situation and acceleration the third member will want to rise up at the nose.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 12-29-2013, 08:36 PM   #13
tincan1966
tincan1966's Avatar
I would agree with this for a leaf spring truck, where you get a slight amount of spring wrap on accell, but with a trailing arm suspension, the angle of the differential varies very little thru the suspension travel and if you angle the pinion downward more than the parallel line of the transmission, you will experience driveshaft vibration and reduced u-joint life.
Old 12-30-2013, 02:08 AM   #14
Captainfab
60-66 Nut
I agree
Old 12-30-2013, 04:22 AM   #15
Rich 5150 69
Has anybody checked the stock pinion angle on their truck...?
Old 12-30-2013, 08:27 AM   #16
tincan1966
tincan1966's Avatar
Yes mine was 3 1/2 degrees UP with stock suspension and only reduced to 3 degrees with the axle against bumpstops on frame. I am currently running at about a 4" drop in the rear and my pinion angle is at 3 1/2.
I had to shim my transmount 1/4" to get them parallel ( most likely could avoid this by researching a thicker transmount) I have the Urethane HD engine mounts which are obviously thicker and raised the engine slightly.
Old 12-30-2013, 11:41 AM   #17
Leverhead
I'm at 3 degree up on the pinion and 3 degree down on the tailshaft and harmonic balancer. The carb flange is @ 0 and my pinion to driveshaft angle is approx -2 to -3....I'll start there. If necessary fine tuning can be had later after some test driving....especially after I get the front disk brake/lowering kit from CPP. They have shims from 1 to 4 deg....they are a little pricey though.
