12-29-2015, 06:03 PM | #51 |
Re: FITech Experiences ?
I bought mine direct from FiTech but they only offer free shipping if you spend $1495. Lol.
12-29-2015, 09:30 PM | #52 |
But Found Her 25yrs Later!
I wonder if 5 years from now, if the internal pump in the FCC goes out, if we can replace it ourselves.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
12-29-2015, 09:39 PM | #53 |
12-29-2015, 10:11 PM | #54 |
I'm buying the FCC because my 65 has the tank in the cab. If I can just put a pump in my tank, I wouldn't need the FCC.
12-29-2015, 10:18 PM | #55 |
Yes. I think you misunderstood my post. What I was saying why wouldn't you be able to replace the pump in the FCC it is just a intank 340lph pump that is inside the FCC. And buy a fuel pump relay. Use the relay with the FCC. Cause you will have to hook the orange wire on the main harness to the FCC that triggers the pump. Use the relay. Go back over to my thread and read why.
12-29-2015, 10:21 PM | #56 |
Okay, yes. I misunderstood.
I guess I'm just asking if the FCC can be opened up in the event the internal pump goes out. I've been looking the FCC over, and I'm not sure if it can be opened up.
12-29-2015, 10:40 PM | #57 | |
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
12-30-2015, 09:05 AM | #58 | |
If you look up part #40102 it's a 340 L/PH Fuel Pump. Quote from there description of part #40102 "This high quality in-tank fuel pump is a replacement for the fuel pump that is used in the Fuel Command Centers (40003). If a mounting bracket is needed, see the 80110 Bracket listed on this page." http://fitechefi.com/default.asp.pg-...riesComponents and http://fitechefi.com/default.asp?cli...one&SubCatID=0 So, yes I say you probably can replace it yourself. |
12-30-2015, 10:22 AM | #59 |
^ Perfect.
That's exactly what I was asking. Thank you
12-30-2015, 11:49 AM | #60 |
Rodsgreen10: I'm reading through your informative posts on the "Simple Green" thread. What intake are you using the FI on? Single or dual plane?
12-30-2015, 06:10 PM | #61 |
No I have never run an aftermarket FI on any of my stuff. Always old school before.
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
12-31-2015, 03:25 PM | #62 |
so let me be the one to ask a dumb question, I guess I would have to relocate my tank and I could not use the behind the seat tank?? or can I just run an inline electric pump
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
12-31-2015, 03:29 PM | #63 |
Not a stupid question.
You can use your fuel system as is. Just get the FiTech Fuel Command Center. It's a fuel sump/pump that works off your existing fuel pump. That's what I'm doing.
12-31-2015, 07:31 PM | #64 |
*** That's interesting ***
Yep, that's the magic sauce! I think everyone here is curious on how well the system performs, especially long term.
Tom Chevy by day... 1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E 2011 Chevy Caprice PPV 9C3 6.0L 1995 Chevy Caprice 9C1 1994 Chevy Caprice 9C1 #3 1995 Chevy Caprice Wagon #2 1995 Chevy Impala SS Mopar by night... 1969 Dodge Charger 1972 Chrysler Newport 2dr Hardtop (27K miles) Plus others... |
12-31-2015, 07:42 PM | #65 |
I'm suspecting it's going to work great.
There's a few YouTube videos out there of guys using the Edelbrock version of the sump pump. It seems pretty simple. Use your existing mechanical pump to pump gas into a small storage tank that has a high pressure electronic pump inside to feed the Throttle body. There's one guy in these forums that built his own.
12-31-2015, 10:05 PM | #66 |
Never Ending Projects
I stopped by the FiTech shop on Wed. and was checking out the systems. I already have my Go Street and Fuel Command Center on order and they are hoping the systems will be in and shipping out on Jan. 15th time frame. I did check out the FCC in person. It is very nice unit and built very stout. It really is a great solution to not having to deal with a new tank setup. Other nice thing is, if I ever sell the vehicle this system is in, I can always swap it back to a carb and keep the EFI for another vehicle. Since I didn't mess with the stock mechanical fuel system, it makes it easy.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
12-31-2015, 10:08 PM | #67 |
I'm looking forward to hearing everyone's experiences as they get units installed. Keep them coming ...
12-31-2015, 10:50 PM | #68 | |
I've really been giving thought to where we - with our generation trucks might mount the FCC. The Driver's side of the core support may be considered the obvious location, but I don't think I want to run hoses from the mechanical pump across to the other side, and then down the driver's side back to the firewall back to the TBI. If I dumped the firewall heater, then that would be a great location.
12-31-2015, 11:04 PM | #69 | |
01-01-2016, 03:03 PM | #70 |
So, there's quite some discussion going on in 'Simple Green's' thread about cold starts possibly related to grounding issues.
Discussion starts here : http://www.67-72chevytrucks.com/vboa...70#post7429670
01-01-2016, 04:23 PM | #71 |
Surfing and found this thread on a Chevelle forum. Some good discussions going on over a few different installs.
http://www.chevelles.com/forums/showthread.php?t=835633
01-01-2016, 11:44 PM | #72 |
Here's another thread in another forum.
Another link within. http://Www.transamcountry.com/commun...?topic=71747.0
01-01-2016, 11:45 PM | #73 |
01-03-2016, 07:15 PM | #74 | |
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
01-04-2016, 12:45 AM | #75 | |
