Old 02-22-2008, 09:02 PM   #1
Dads 68 GMC
Dads 68 GMC's Avatar
neutral safety switch location?
anyone know this switch is located if not on the tilt column?
Dads 68 GMC is offline   Reply With Quote
Old 02-22-2008, 09:16 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: neutral safety switch location?
Anymore info? Is the steering column stock, transmission stock? If it is all original, I've never seen it any other place.
68gmsee is offline   Reply With Quote
Old 02-22-2008, 09:24 PM   #3
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Its #35 on the parts page.
sneakysnake is offline   Reply With Quote
Old 02-23-2008, 01:57 AM   #4
Dads 68 GMC
sorry I didnt give more info. this tilt column is out of a 71 suburban. I bought it from a guy so I wasnt able to look @ see where the switch was mounted, maybe on the tranny,is that possible? this column never had a switch mounted on it.thanks for the help,Philip
Old 02-23-2008, 02:43 AM   #5
68gmsee
Active Member
68gmsee's Avatar
Dads 68 GMC, still don't have all the info. The things we need to know to be able to help are:
Year, model, engine, transmission (manual or auto), stock, if modified, what mods has it had, etc.
I will assume your truck is auto... If it's running try to start in drive or reverse (make sure it doesn't take off) and it cranks, then you don't have a switch installed. If it doesn't then check to make sure you have backup lights... The switch controls both.
If you don't find the switch on the column, then it could be on the tranny (haven't seen one there though) or, as in the case of some newer manual shift trucks, activated by the clutch pedal so that you make sure you're not going anywhere before you start the truck..
Other than that, I'm lost... Let us know what you find...
Old 02-23-2008, 03:58 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
if it is unmodified, and originally an automatic, then the bottom of the column is the only place it would be.
Old 02-23-2008, 10:09 AM   #7
Dads 68 GMC
[ATTACH]Name:  Steering column 006.jpg
Size:  64.5 KB[/ATTACH]
ok,more info. the truck is a 68 gmc 4x4 350 converted to auto,turbo350. the stock 4 speed column had a nuetral safety switch on it. the closest column in the picture never did have a safety switch, it is out of a 71 suburban. the 2nd column in the pic. is a van tilt with the switch mounted 10" from the shift collar, which will be in the way of mounting it to the dash. I saw a faq on installing a switch on the column but what I dont know is how to make the notch in the inner tube, the outer tube will be no problem with a die grinder. thanks for any help.
Old 02-23-2008, 12:38 PM   #8
Longhorn Man
that closest column is a van unit, that's why there is no hole for the NSS where it is supposed to be.
Old 02-23-2008, 07:12 PM   #9
68gmsee
Active Member
68gmsee's Avatar
Yo, Dad's, lots more info.
I knew that someone would come up with an answer... And I sho' didn't know that vans didn't have nss.
Longhorn Man do you know where they put the switch since it wasn't on the column?
Old 02-23-2008, 07:19 PM   #10
RED71CHEVY
RED71CHEVY's Avatar
you can purchase a switch from LOKAR that attaches to the trans......i have this for my reverse lights, i also am using a van tilt.
TIM
'71 CUSTOM C-10 torch red ,350 roller GM crate,3.73 GEARS, REAR 4"DROP SPRING, FRONT 2.5" DROP SPINDLE-1.5"lower spring, FRONT=17x8(4.5bs) W/265-60-17, BACK=17x9.5 (5bs)W/285-60-17, Vintage Air Sure Fit AC------NEVER ENDING PROJECT!!
RED71CHEVY is offline   Reply With Quote
Old 02-23-2008, 08:04 PM   #11
Dads 68 GMC
thanks much,I'll try lokar, that sure sounds easier than mounting one on the column, red71, would you have a part #?
Old 02-23-2008, 08:11 PM   #12
RED71CHEVY
RED71CHEVY's Avatar
just tell them yuo need a backup/neut safety switch that mounts to the trans. they will know what you are talking about.
TIM
Old 02-23-2008, 08:21 PM   #13
RED71CHEVY
RED71CHEVY's Avatar
jeggs #625-BL-1400U $$22.00
http://www.jegs.com/i/Lokar/625/BL-1400U/10002/-1
TIM
Old 02-24-2008, 01:30 AM   #14
Longhorn Man
its crazy that the one doesn't have a NSS..it IS a van unit though... both the tilts you have there are.
Even though, it SHOULD have one in the same spot as the second one.
Old 02-24-2008, 04:34 AM   #15
68shortstep
Looks good at 20-ft .....
68shortstep's Avatar
Maybe - just a guess: Non-auto trans motor home or step-van or some other oddball van tilt usage ?
68shortstep is offline   Reply With Quote
Old 02-04-2012, 08:41 PM   #16
starvinartis
The closest one does appear to be a motor home tilt for auto trans which would mean Turbo 400 trans w/switch on trans (?) The odd thing to me is that the green 4 speed standard trans column has a hole for the switch, and you stated it had a NSS, but those trucks only had a reverse light switch on the trans, and no nuetral safety switch that I've ever seen,( how would it work?). Perhaps they just punched all the column tubes on the assembly line...
starvinartis is offline   Reply With Quote
