Re: aluminum radiators and mounts
Double post
I bought that radiator from them back in June. Very good radiator for the price. Im using a dual fan setup and it keeps my temp pretty steady. The only thing I had to do was get new smaller mounts (3 row) and rubber. But other than that, perfect fit and performance!!! I highly recommend.
I have the regular radiator now and was wondering what radiator mounts I might need to install this. I ordered it last week and just waiting on some shipping info. Hopefully it is on the way.
i think Ill use my stock fan for a few weeks before I go to electrical fans. Hopefully I can find a good shroud system with electrical fans that will fit it. |
Anyone have some contact information for this company other than sending a message through ebay?
The upper hose already had the extension, I tried to find a longer one but the parts houses around here can only look up in a computer,very frustrating.
My truck still had the original 6 radiator which was a little longer. I drilled out the rivets in the bottom mount and moved it and little pop riveted it back in. |
He confirmed earlier that mine went out and i should have a tracking number later. |
Yep it uses the smaller mounts and rubber. Fits exactly like original.
I used the smaller mounts that were on the original 6cyl radiator. I just had to move one in a little.
Mike Hammond |
YYMV |
4 Attachment(s)
Here's a few pics of my entropy rad I installed today. I used my 4 core rad mounts...had to shorten them. I had to trim the new lower rubber inserts to get the rad to sit at the right height. Pretty easy install overall.
SC |
Nice!!!
If you had to shorten your 4 core mounts, sounds like the 2/3 core mounts sould work perfect. Can't wait to get to the point of installing mine... |
I can use my 6 banger rad mounts then. :lol: Quote:
Those look hot man! |
The fans are Spal units...they were part of the deal with the radiator. I have to say the radiator and fans/shroud are very, very well built. I also went ahead and got the fan relay/harness assembly as well from Entropy.
SC |
Updated my radiator info in my build thread with pics, a brief description and installation will be tomorrow!!!
http://67-72chevytrucks.com/vboard/s...53#post3637453 |
Updating my build thread once again, Radiator is installed, and it sure fits NICE!!
:metal::metal::metal: http://i25.photobucket.com/albums/c6...2/IMG_0634.jpg |
Need better pics!!!!!
Install looks great. Was this the radiator from the first link you posted or the Entropy one?
