Re: '68 air ride.
But it's all good my friend word of mouth now a days travels fast :) |
Re: '68 air ride.
Re: '68 air ride.
Re: '68 air ride.
names matter bro. negativity is the hardest thing to overcome for ANY business, much less a new business. regardless of whether it's true or not. not trying to beat you up, only offering a perspective from a person who has purchased thousands of dollars in air ride components over the past 10 years or so. as a consumer, negative word of mouth travels much much faster than positive. |
Re: '68 air ride.
I agree with you to a point and this is a good conversation so no worries about beating me up. This is good info, look man the good can't come with out out the bad. The bad is telling you what you need to fix or improve on. So hearing anything from customer could and should be used to help move any company forward.
I do agree bad news travels very fast. But you have to remember the C10 "group" if you will is small and tight bunch compared to the rest of the industry. So it is a little easier to separate yourself or make waves...lol. Also Alot of big and small companies in AZ use us to buy accuair or Airlift products because we always stock deep. |
Re: '68 air ride.
Travis you guys should look in to becoming on a vendor on here.We have a huge market on here with all the years trucks on here.
Re: '68 air ride.
Your right. Im gonna look in to that. Run special for any member of this forum. Let me find out how to do that.
Re: '68 air ride.
Re: '68 air ride.
You only spend 10k on Porterbuilt if you use the extreme level kits. If you use the entry level kits it will be comparable to other kits
Re: '68 air ride.
So, has anyone used the airmaxx kit? I'm just looking for a system more for lowering when parked and lifting while driving. Already have a 2-5 lowering kit but looking for a better stance and a little lower while parked.
Re: '68 air ride.
I would do it! I would also add this to the set up
https://store.airslamit.com/default/...ual-panel.html Azle |
Re: '68 air ride.
For the OP.... you dont need a kit! Its not hard to bag a c10! Look at my bagged hot rod thread! Real deal top of the line equipment for cheap! If you know what to get then you can save money by shopping around! And for anyone wanting to ball on it cause its manual ....oh well thats what i wanted! I could have had the slam specialities manifold for $100 more but decided to keep it simple, accuair v4 would have only been $200 more😂
