Re: Take the old off or leave it on ,that's my question
My cabin is in the Tahoe National Forest. It has a corrugated metal roof because wood shingles have been outlawed for years!
I'm not a roofer but I would never shingle over another roof. If for the only fact is you need a new roof then you need to check the wood under the shingles for any water damage. I wouldn't sleep good not knowing if I missed something.:chevy:
No tornados , no Hurricanes ,,not even any big hail storms ,,just small hail and not much wind storms over 30 mph .. so I was thinking that another layer would keep the cold out in the winter and heat out in the summer.. I knew there was some chance of a bad roof ,, I have 80% of my house vaulted ceilings . but.. I will go ahead and get the old off as I find a roofer and hire it done ,,the roofer will probably not warranty the job.. |
unfortunately there is a lot of fly-by-nighters in the trade...some dude helped his cousin Billy "tar some shingles" and all of a sudden they think there a master roofer..puttin' shingles down on a strait, open go is not hard, it's when they hit the details, stacks, valleys, walls, etc that piss poor workmanship shows up. i would bet a good 80-90% of probs i deal with can be traced back to shoddy work, or they just didn't know how to do it. i've seen it all, and i mean all-right up to a homeowner who put his shingles on upside down... guys that won't warranty their work do it for a reason, ie lack of knowledge, a corner cutter or whatever...it gives guys who have dedicated their life to roofing a bad name. a seasoned roofer can give you a good idea of the shape of your deck just by walking around it and doing a little poking around. if you can't see any rot from inside your attic, 99% of the time there will be nothing to worry about topside of your deck. rot doesn't just stay on the top, it goes right thru your wood...you'd be surprised at some of the materials i've seen nailed over top of rot by "professional" roofers... a vaulted ceiling is even easier to check before ripping off or going over top. this is a torch-on roof i did in '81, when torch-on first started hitting the market, 40 yrs and still going. if your roof is done right you will get good performance and life from it Attachment 2093389 |
in 2007 I gutted my first home and re did the electrical and plumbing and everything else including the roof. I pulled permits and everything was inspected. I have others do those things now but what a wealth of knowledge. Now when I get something done I look up the procedures in the codes sections online so I can tell if they are doing it right. I pulled 4 roofs off that house. It has rough sawn cedar rafters and 1x6 cedar for a base for the shingles. It was sagging before I removed the roofing. Not now. Not one of those boards had any rot and the home is a 1959.
actually when you get your roof done, there is 2 warranty's. one from the shingle manufactor for material defects or shingle failures, and one from your roofer for workmanship.
almost all shingle brands warranty over top...but be aware, 9 1/2 times out of 10 they will claim improper installation if a prob arises, which sadly in my experiance, is true. like i said, water has very narrow shoulders, it WILL find poor work. here's an excerpt from GAF shingles; "The GAFMC Smart Choice limited warranty provides coverage against inherent manufacturing defects in the shingles regardless of their application. Even if your roofing system was not properly installed in accordance with GAFMC's application instructions, the limited warranty will remain in effect against manufacturing defects. However, the warranty does not cover any damages to the shingles or roofing system resulting from anything other than an inherent manufacturing defect. It is a standard roofing practice to install shingles over the top of existing shingles. The limited warranty on the shingles affords the exact same coverage for a single or multi layer. If you have any concerns or questions regarding the application of your roofing system, please contact our Technical services hotline at 1-800-766-3411. Thank you for choosing GAFMC products, we appreciate your business." but further into their warranty.... "GAF's studies indicate that more than two-thirds of the problems that people experience with their new roofs are due to the contractor's workmanship, not the roofing materials. This is an important distinction to keep in mind when deciding on warranty coverage." like i say, unless your a ticketed roofer or are an authorized installer (meaning you took that shingle manufactor's courses on how they want them installed) they will quite often push claims into the workmanship catagory. we give out between a 5 to 10 yr warranty on our workmanship depending on what the owner decides. if you have a workmanship prob, 99% of the time it will show up within a few yrs, still in your warranty timeframe. and in this business, your reputation is EVERYTHING. nobody ever remembers a good job, but everyone will remember a poor job... |
You could peek into the attic and tell from there. |
your right
if you use osb most standards call for a min 5/8's deck with clips, if using plywood 1/2" clipped is the norm, but some areas will also accept a 7/16" deck. as noted look inside your attic to see what you have, as both have been commonly used for for decks since the '80's. |
I seen plywood 4X8 X 3/4 going for $95 a sheet the other day.. |
I was just going to put new shingles on over the old. What do you guys think?
Looks like something Bob Ross would paint. Look at all the happy little trees on the roof. |
My guess is that this roof ought to last another year or two at least ,,I found an electric wire going to the house and so I hung up some Christmas lights on the trees ,, and then maybe I'll fall the timber after a few years and go ahead like I wanted and just roof right over the roof that's on there. .what do think?
Attachment 2095433 |
Pretty soon that roof will be declared a Wilderness Area ;)
