Re: My 68 c10
4 Attachment(s)
Here it is my truck crooked finally is laid in the front
i didnt take pic of it layed out up front. only fully raised but here they are a long day of work thanks to my dad and my buddy jeremy |
Re: My 68 c10
Right on, lookin good!
Re: My 68 c10
when you said somehting about going to the sonic on my thread did you mean in a****er
Re: My 68 c10
awesome!!! No discs?...
cant wait to see it laid out! |
Re: My 68 c10
Just used some plates and cups or what??
Re: My 68 c10
And for sure ill put pictures of it laid out tomorrow. well the front laid out. |
Re: My 68 c10
Re: My 68 c10
4 Attachment(s)
Here are the pic i took today so i can show you guys how crooked looks laid in the front
planning on doing the rear this weekend possibly |
Re: My 68 c10
more
Re: My 68 c10
You have drop spindles on it at all?? What are the plans for the rear?? Truck looks good man going to have to cruise up to fresno sometime and check it out
Re: My 68 c10
my plans for the rear is the super notch and run the trailing arms for now and save more up to buy my wish bone setup. but yeah im gonna do my setup myself. i work at an exushuast shop welding exhuast all day and im trustin my self and my welds to do it all my self. And yeah im taking my truck to the Freaks of Nature show in august here in fresno. underconstruction. |
Re: My 68 c10
looks awesome man! so just cups/bags?
Re: My 68 c10
yeah just bags and plates. no drop spindles
Re: My 68 c10
what is the date on that show man. I want to do my bags soon but never really messed with the as far as wiring and routing. I need some guidance on what to buy, I want them to be slow a quite, Thinking on just doing the fronts first on my truck. Let me know heres what i believe i need. Upper plates and lower cups, bags, fittings, lines, compressor, about a 5 gallon tank, and valves but dont know which ones fill me in on your set up and costs of it if you dont mind.
Re: My 68 c10
i got a simple setup i spent probably 200 on my front setup with just the bags and cups plates and lines fitting etc. but i am runnin a t too a bike fitting for now i got danz vavles i need to put in but i want to get parkers they are really great. |
Re: My 68 c10
your running what kind of fitting and since you dont have valves are you still running the compressor..
Re: My 68 c10
well right now i mounted my compressor so i can hook them up when i need too.
the fitting i got from avs which is right around the corner from my dad. i got the 90 degree swivel push pull connectors on my bags and once everything like frame mods are done i will purchase the rest of my lines so i can run my compressor tank and valves |
Re: My 68 c10
How much more can you go down in the front before the control arms are on the ground are your cups cut
Re: My 68 c10
oh so if you where to drive the truck you wouldn't be able to dump it out and raise it up as you please because everything is not hooked up
Re: My 68 c10
and thats with out my drop spindles so once i put my drop spindles on my control arms so lay on the ground especially since im going with smaller tires Quote:
Re: My 68 c10
Oh ok, that would be a big problem for me. Was looking on a few sites last night seen a few 5 gallon tanks and a 9 gallon one that looked nice, I dont understand why some have larger holes then others and how many i actually need.
Re: My 68 c10
nice work
Re: My 68 c10
you keepin it 50th annversary style when you repaint also about your steering wheel and horn cap whats the plans with those
Re: My 68 c10
Re: My 68 c10
purchased my c notch today and now gathering up more money so ican buy the rest of my stuff i need and my drop spindles tomorrow is payday so i get more money to spend on my truck
Re: My 68 c10
A big c notch or just a bolt in?? Finally got me a job so will be doing rear disc brakes on my truck soon.
Re: My 68 c10
yea the super c weldin it in not bolt on lol
Re: My 68 c10
Damn that means a hole in the bed is coming soon, Im just going to weld a pipe in my frame and when it hit it hits.
Re: My 68 c10
Hey, I love the way the truck is coming along!! Looks great. I have a quick question. What kind of lowering set up did you use on the truck? I have a stock 72 LWB and I want the ride height to look just like yours. Can you tell me what you did to achieve that look? Also, where did you get your 700r4? I picked up a used one that was rebuilt and I have had nothing but problems with it. I paid 750 for it. I am wishing I saved some more and purchased a brand new one. Can you tell me where you picked up yours? thanks a ton.. keep up the good work. Like you I started working on old trucks with my dad, 46 chevy truck, now I am into one of my own. Still learning too...
Brian Quote:
Re: My 68 c10
but thanks alot for the kind comments also about my 700r4 i took it out of a 93 camero. i got the tranny for free as long as i pulled it out it was mine. |
Re: My 68 c10
Today i took crooked to the frame shop. Crooked is no longer crooked but it will always be called crooked.
and i pulled out a 350 for crooked 4 bolt center. i am saving up this week and next weeks pay so i can get my engine rebuilt. and this weekend i can finally probably start workin with my notches |
Re: My 68 c10
any progress jesse
Re: My 68 c10
well i havent done anything to crooked in a while but i will soon im savin my money for the engine rebuild and my wishbone link kit! =]
Re: My 68 c10
look'n good jess
Re: My 68 c10
Dang, that engine looks brand new, and it needs rebuilt? Looks good in there. And I'm partial to your trucks color. Soon to be mine also.
Re: My 68 c10
the motor in it has a flatten cam or the shaft to the rocker collaspe |
Re: My 68 c10
sweet
Re: My 68 c10
hey jesse, how did you clean/prep your frame engine bay area for paint?
Re: My 68 c10
thats a good lookin truck you got their, good luck with the continuing build
Re: My 68 c10
