Re: Post Pics of your Static Drops!!
Hmm. cant decide what to do. I have factory overloads on my truck that are nice but sure arent usable once lowered....
2.5" drop spindles w/3" drop coils in front. 5" coils w/2inch blocks on back.
Hey badriand...
You just have coils and shocks on the back, or a cnotch too? What about panhard bar or shock relocators? I'm about to buy a 3/5 spring and shock kit and am wondering if I will be ok in the back with just that, thanks! Posted via Mobile Device |
Oops for to add ApacheWillard. Yea i have a C-notch on back and a shorter panhard bar. No shock relocators. I did a notch with 5" coils on back and had tons of clearance ( at that time really didn't need notch). Now that i have added 2 inch blocks with the 5 inch coils i need the notch. Can't say for sure if you need notch or not (you can always add later or just take coils off and drop truck down and see what kind of clearance you have without notch.
I also did mine 5" and 7"
front- 3" springs-2" spindles rear--5" springs-2" block (slightly shaved and angled for pinion) I C-notched the frame along with an adjustable panhard bar. The top of the rear is actually closer to the bed wood than the rear to the C-notch. I have about 3" from the rear to the wood. No problems though 20" wheels all the way around |
Here is a shot without caps on. Looks better maybe.
here's mine front has POL tubular UCA/LCA, 2.5" drop spindles, CPP 3" drop springs. the rear just has CPP 4"drop springs
http://i303.photobucket.com/albums/n...0/DSC03065.jpg http://i303.photobucket.com/albums/n...0/DSC03067.jpg http://i303.photobucket.com/albums/n...0/DSC03064.jpg http://i303.photobucket.com/albums/n...0/DSC02879.jpg http://i303.photobucket.com/albums/n...0/DSC02813.jpg |
Also what size tires are you running? Looks good. |
here are a few more for reference http://i303.photobucket.com/albums/n...0/DSC02883.jpg http://i303.photobucket.com/albums/n...0/DSC02840.jpg http://i303.photobucket.com/albums/n...0/DSC02838.jpg |
3" drop CPP Springs in the front,6 inch drop ECE coils in the rear.
http://pic20.picturetrail.com/VOL90/.../320587654.jpg |
haha sweet!:metal: how much more (or did) the POL arms drop you? looks like how the lower arm 'cup' sits it would drop your shock height right? |
Can you tell me about notching the 62 frame? I've got to do it yet... thanks.
2 Attachment(s)
New to the forum and thought I'd learn about posting pictures. This is my work in progress/daily driver when theres not 6 feet of snow blowing around way up here. It's only lowered a little but I figure that counts for something.
I see alot of people on here with six lugs who say they are using drop spindles. What spindles are you using, and did you have to change to disc brake set up? What rotors are you using if so?
The aftermarket drop spindles that you see are set up for HD brake using the 1 1/4" rotors vs the LD 1" rotors. So if you buy the drop spindles you can run stock HD 1 1/4" 5 lug rotors or aftermarket 6 lug rotors... OR you could run the 6 lug rotor on a stock HD spindle if you don't want the drop. I'm unaware of a LD brake rotor option that would allow you to run 6 lug wheels... Let us know what you come up with and PICS are always fun too! |
http://i630.photobucket.com/albums/u.../temporary.jpg |
2 Attachment(s)
ccp drop springs, notched in rear
cut 1.5 coils up front off of stock spring; rear has 1998 jeep grand cherokee rear coils with 1 coil cut and 1-5/8" lowering blocks (they were 2" blocks)
rides smooth and handles great for a cheap drop http://img856.imageshack.us/img856/1508/img2016d.jpg |
