Help...1972 350 W/HEI
Any insight would be appreciated.
Stock 350 with HEI, and i converted to a 1 wire Alt. I replaced the Module, Rectifier, Cap and Rotor. New Carb, Sending unit, lines. Fires right up. Idles Great. BUT...she dies under load, only when shes warm and in motion. Air fuel mixture? Open Circuit from my alt? (its charging the battery just fine at idle) |
Re: Help...1972 350 W/HEI
What carb?
What’s your timing like? |
Plug gap? With an HEI you should open them up to around .045
Gary |
Check the easy things first.
Couple of things to look at. When idling, check to see if you are getting at least 14.5 to 15 vds when measured across the battery posts using a volt meter. Check fuel flow from fuel pump by remove inlet line to carb, place in plastic container and see if you get at least a pint of fuel in less than 30 seconds. If you don't, it could be bad fuel pump or restricted fuel lines. |
20-24 degrees!
Did you Check it with the vac advance plugged off and at the lowest idle rpm? Where’d you get the carb? |
That's another issue I need to figure out. Ported or manifold vacuum? My advance is plugged into my carb, I have read conflicting statements. Don't know, Had a shop order it, it was running great. Now its not. I'm heading home to mess with it today. |
Make sure you plug off the vac advance when you check the timing.
Ported or manifold vac? Let your motor decide. Try them both. |
Original HEI or points? If points, did you remove the resistor wire/block from the power wire to the HEI?
Volt reading with headlights on, blower on max and wipers running while revved up a bit? (quick and dirty alt check while on vehicle). A downside to one wire setups is no allowance for voltage drop in main output wire under high load. Double check for vacuum leaks. Accel pump on carb working? I run manifold vac for the advance but like others have said, try both. With vac advance pot disconnected, a good start timing is around 8. Once you have your problem fixed, add more until it either gets hard to start hot or you pick up some pinging on load. This gives some allowance in case your timing mark is off a bit from true TDC. (It happens) Mine likes around 12 by my simple timing light. |
Just as an fyi: When checking timing, plug or cap the vacuum port on the carb that goes to the vacuum advance. I'm sure you already know this but I've seen some do it wrong.
Re. ported vacuum or manifold vacuum. After you check the timing you can hook it up either way to see where it runs better. Manifold vacuum is below the throttle butterflies on the carb and ported vacuum is above them. |
Intuition tells me either fuel pump or coil. Both of them will get worse when hot when they are failing.
Some thoughts: How do the plugs look? If you take the air filter off and open the throttle, do you see the accelerator pump spray gas? Does it happen after it dies? The hard part here is you stay it happens with the vehicle in motion. Can you have the vehicle in drive, foot on the brake, hit the gas a bit to put load on it and have it die? If so, to test spark, you can try putting the timing light on a plug wire and see if it stops sparking as soon as it gets a load on it. Try it with a couple different wires. For fuel, you can try squirting some fuel in the carb when it starts to die. Can use starting fluid (in a spray can, so this might be safest), dropper, or a bottle. Might be able to use carb cleaner. If spraying fuel makes it come to life, it is a fuel issue. |
was itt running ok before you messed with the charging system. There is “ask a mechanic” option on your phone. Lol. Maybe it’s a APP
Posted via Mobile Device |
You removed the points, installed an HEI and started having problems - correct?
I didn't see a voltage check at the dist mentioned so here's a question. Did you run a dedicated wire to the HEI or remove the in-line resistor? If not, then even with good batt voltage the dist. won't see 12v. To confirm with 100% certainty that your voltage is good at the dist, grab a volt meter, pull the connector from the HEI and measure the voltage to ground. It should be the same as your battery. |
Let me start over.
It's a 1971 350 with HEI that was in my 71 C10 BURB, running and driving with zero issues. Pulled it and put it in my 72 K10 Burb that was still points. I had a well known hot rod shop in my area do the swap for me. New tank, New Lines, New Q-Jet Carb. Ran great, even driving it @ 50-55 MPH went about 40 miles, but...... It didn't charge. Even with new Alt, New Regulator, New battery. so I decided to convert it to 1 Wire. (1) 6 Gauge wire strait to the battery. It charges with no issues. I disconnected the external regulator and linked the wires as i have seen in multiple diagrams. I re-checked the timing again last night. disconnected VAC ADV(which was plugged in below butterflies) Set it @ 8 Degrees with vacuum advance open, and the vacuum from carb capped . Plugged it back in to same port- no change. plugged VAC ADC (into port above butterflies) and the timing advanced a good bit, so id decided to take her for a spin and same problem. Obviously it has to do with the ALT right? It ran fine before hand. What am i Missing? Since its a one wire and I have no idiot light, do I need to convert it to a 3 wire? Could that possibly be my issue? Thanks again |
Did you check the fuel pump output to the carb?
Pull the line off the carb, put it in a quart jar, unplug power to distributor, crank it over. It should fill the jar in under 30 seconds. |
Quick question. What does the amp gauge read when idling or at higher speeds?
On a fully charged battery with AC, radio, lights turned off you should be able to run the truck for a few miles at highway speed. I've done that on mine. I have a one wire alternator I bought at NAPA for my tractor and it's worked great for many years. Other things to check all the ground straps -especially from engine to cab. On my 68 my gauge wouldn't work until I installed several ground straps including one from radiator support to the battery ground. |
And while you have the fuel line off, check the fuel filter in the inlet to the carb
If the pump checks out then leave the filter out for a test. Be extremely careful removing the inlet fitting. It's fine Threaded and easily stripped. . |
The whole point of a 1 wire is it doesn't care about any outside connections other then the primary charge output wire. |
What he said 100% If the work was done by a well known shop then it should be fine - but it isn't. I bought my 73 from a mechanic who works at a reputable shop. When I asked why he hadn't converted to HEI he said he tried and it didn't work. The reason it didn't work was because he used the old ignition wire with the resistor. The first thing I did was run a new ignition wire and install an HEI. Haven't had a single issue since the first start. |
Don't have one.[/QUOTE]
Re. my comment on amp gauge... Only reason I mentioned is you asked if the alternator could be the problem. I haven't used a single wire on a vehicle but my tractor has a volt gauge that I use with no problems. You may be able to rewire an amp gauge in series using heavier gauge wire or or add a volt meter to your truck. |
You said "6 Gauge wire strait to the battery. It charges with no issues." Why do you think "Obviously it has to do with the ALT right? It ran fine before hand."
If it charges fine with the new alternator, then what's the problem? What makes you think it has to be the alternator? What is the voltage showing while you are driving. The alternator not charging shouldn't affect the way the engine runs. It will run off the battery just fine. Verify the charging system is the first to do. Hook up a volt meter to see what is actually happening. |
The reason I asked is because that was the ONLY thing that I messed with. I didn't think it was the issue just wanted another opinion. |
Make sure you are grounded good....
Did you check the timing, seems like that is a hot item to check on this forum. |
https://www.americanautowire.com/vie...d-connections/ But: Once I realized that i could start and keep the truck idling (even with the other wire running to my starter not connected) I deleted the wire to the starter. I did not replace the entire wire yet because I am seriously debating getting a painless harness because someone has already been in there messing with it. Took it for a test ride and same Problem. Quote:
Was the old module AND the new module doing this?? If not, then try another module.
Thanks for all the help fellas, especially the ones that said the ballast wire needs to be replaced, it was not.
Replaced the wire from the firewall to the Distributor and it Ran Great, all the way until it died due to carb getting too hot. only way it will start is WOT. So now onto a spacer to rectify that problem. Any preference on spacers? for a factory Q-Jet, Factory intake. |
I only suggested you confirm the voltage to the dist since it's easy to overlook and I didn't see anything in your post indicating you had verified that - other than the swap was done by a reputable shop, but maybe I missed it.
Spacer won’t cure the flooding problem! Find out why it’s flooding. |
I hit the throttle linkage on the carb and when it sprayed gas it just started smoking(out of carb) hence the spacer idea, i figured it was like that because of how hot it got. So flooding is my main concern, Am I wasting time and money with a spacer? |
you said new carb? where did it come from? New or rebuilt? Some QJet experts might give you some tips.
Needing to go wot to start it means it needs more air to mix with the excess fuel in the carb/intake.
The smoking isn’t from heat. It’s excess fuel vapour. Looks like smoke. Any carb that floods does that. Look in the carb while cranking it over or when you get it running. Any fuel seen at all means it’s flooding. Could be dirt in the needle/seat or a sunk float. |
Agreed, stock carb on a stock manifold shouldn't need a spacer to run right. It does sound like it is running rich.
I had one get all crazy rich on me once and a dirt dobber had decided to plug the bowl vent!!
Rebuild kit on order. Quote:
Did you put the needle/seat back togethor correctly. The clip installed wrong causes flooding.
http://www.crankshaftcoalition.com/w...4MV_carburetor Like in here. |
https://quadrajetparts.com/used-floa...319-p-398.html BUT because the reman one has this in it: https://quadrajetparts.com/carbureto...ket-p-438.html I had to shave down the sides and but out the center of it just to make it work. I have a 71 Q-Jet, and a 72 Q-jet that don't have the repair done. but they do need a GOOD cleaning, any benefit to rebuilding one of those? Since im doing it anyway. The float hinge is different on the repaired one, that is why i needed to shave it down. I hate to think of wasting the 500 on the reman and just shelving it, but I just want it done right. Thoughts? |
Gotta hate that cobbled togethor stuff.
I’d bite the bullet and rebuild one of the others with a much better kit from Cliff Ruggles. |
That's what I'll do. Thanks again for your input. |
It could just be a float adjustment. If there was trash in your new carb, I assume you cleaned the needle and seat good. Were the primary needles moving smoothly/ not jammed or stuck?. If the needle and seat looked clean and the primaries are working like they are supposed to then I would just lower the float and try it again.
