new top
OK, at the risk of sounding like a complete idiot I'm going to ask a question (which I'm sure someone has asked in the past). Has anyone fabbed a custom top as a replacement for the jimmy/blazer? To be more precise a top that is not fiberglass.
I was thinking of making a top that actually sealed well, and perhaps used truck doors instead of the blazer/jimmy doors so the glass would seal well and not leek air/water. Rokcrln posted the thread: Need info from the blazer crowd please! a couple of days ago and it got me thinking. I would still use the normal doors when the top was off, when the seal didn't really matter, but would use the truck doors with the new top when the weather required. I'm thinking about trying to make it out of something lighter than the fiberglass tops that wouldn't sag like they tend too. Perhaps aluminum or carbon fiber (painted of course, I'm not going for the import look). I still want to retain the lift hatch as well as side windows and the dome lights, just put in newer replacements that will compliment the new top. I would also like to stay fairly close to the shape of the original, i bought a pre 73 for a reason and would like to stay true to the body style. I guess the goal would be to create something stronger and lighter with the functionality still in tact if not better. So like i said I'm going to throw this out there. In my defense i looked for another post with this but couldn't find one along the same lines, but i could have missed it:new: Anyways, input would be much appreciated. |
Re: new top
Would you really want to change your doors every time you took the top off? Sound like a huge hassle. Plus the paint could possibly fade differently if one panel was exposed to the sun more often then the others. I have not seen it but I would guess that a top could be fabricated from a suburban If you wanted to stay away from fiberglass) and made to fit the windows a little better. It couldn't be much heaver.
Re: new top
but then again, i'm in so cal, we don't get a tremendous amout of rain anyhow. |
Re: new top
As far as the panels fading because of different exposure to the sun I'm not to worried. It only takes me about 10 minutes right now to switch doors but I haven't added power windows or anything so there are no cables for me to disconnect.
I have all of my new weatherstrip awaiting install, and that might make the seal good enough, that is true. But I was kind of hoping for a really good seal in case of poor weather. I live in Idaho and granted its not rainy in the summer... at all in fact. But during the winter, and especially this year, it seems like we've been getting a lot of rain. I also would still like to be able to address the sag issues. The rig that I'm hopping to do this for will be a trail getter once a week or so but also a daily driver. I would really like the top to be able to take more abuse without the worry of hurting the fiberglass. Then again i might just be a glutton for punishment and feel the need to start a crazy project.:crazy: |
Re: new top
I've got plans to build one soon (if the !@#$ tranny guy would give it back to me!). 2-piece, Plexi windows, aluminum frame, and polyethylene roof. A few cosmetic changes, but should be good.
Re: new top
I'm thinking the regular doors would help with the top strength issue, but really don't know how you would go about it. Unless you went with the Sub top idea. Maybe you could make mold from the leading edge of the old top to get the windshield area to seal right, then modify the door openings to accept the door tops?
I'd love to attempt something like that, I just don't have the ability right now. I'll be watching to see what you do though! Keep us updated! |
Re: new top
I was thinking of cutting a truck top!? Perhaps thats a stupid idea, I'm not sure yet. mister.freeze can you describe your top more extensively? I need all of the advice I can get. Thanks again guys
Re: new top
Re: new top
:bling2: |
Re: new top
Re: new top
I was thinking that someone could fab up an open-back, half top that could mate to a conventional truck topper. If you could find the right topper, it might be pretty cool.
Re: new top
Definitely an interesting idea but the undertaking could/would be enormous.
Couple thing's I'd like to throw in: #1-Lighter is good but improbable IMO. If you built a top designed to take wheeling abuse, it won't end up being any lighter than a stock hard top. #2-Changing the doors will get old fast but you could always do a jeep style quick release hinge I guess. #3-What about a removable upper loop for the doors? Instead of changing out the doors, install the "winter" door metal that will seal tighter to the new top. (not the biggest issue IMO though) #4-Mating to the windshield frame will be challenging at best. Why not modify a stock top to meet your demands? Address all the issues you don't like and need improvements and work from there? Keep all the good attributes and change the rest. |
Re: new top
Not sure the window channel is a good idea, been wrong before, seems like GM had the thought of the glass sliding over the seal. We all know how these bodies bend and flex, the glass could bottom out in the channel and shatter. It only seats in a 1/2". Not much margin of error.
Maybe I missed your point, and your saying to mount pickup doors. Then it seems the door channel could get wedged in the top area. Heck, I don't see where a little water or air is a big issue. Nature of the beast, I've had convertibles since HS and you just live with it, and keep an eye on things. Just seems easier to build up the area on the hardtop where the seal mounts |
Re: new top
Explain in deatil? Kinda tough, but I'll try. I've got the part that mates to the windshield cut from another top, and this will make a flange mount. I'm making a wingstyle rollbar the shape of the top behind the front windows. The back half will pretty much be a camper top that butts to the wing, but in the shape of the original. the roof will come down to about where the top of the original windows are, and the sides will be plexiglass. The back hatch will be a single piece of plexi. Not sure if the front part will be 1 piece or a t-top yet.
