eaton limited slip
well i have been having many questions but no one gives me a straight answer. ever since my bbc went my in truck, its hard to gt traction. i have a 12 bolt rear from a 71 c10 that cam with a th350 and a 307. i saw some summit racing limited slips posis but im not sure what one to use. they keep saying "for passenger cars" is that not the one i need. i type in the model of truck and nothing comes up. are all 12bolts the same? i also need 4.11 gears. can someone give me a link? i have roughly about 700 buckaroos to spend, thanks.
Re: eaton limited slip
12bolt truck is different from 12bolt car//try googeling randys ring and pinion or speedway motors might have a better list// or wait till monday and call summit and talk to a live guy
Big blocks came with 3.08s because of the higher torque.The lower the gearing the higher tendency to break rear wheels loose.
I like Randy`s and another great company is Reider Racing.They`ve beam around forever,very knowledgeable,and helpful.They are gear specialists.www.reiderracing.com The only differences within the truck 12-bolts is in the carriers themselves,depending on gearing.The break-off is 3.73 lower and higher. For the street,I like the factory (Eaton),but really like the Auburn the most. |
if you contact summit, they have auburn truck posi. units for sale. try looking in 4x4 section instead of race/ car section last one I bought was from them and it worked great.
