frame swap?
does anyone know off a frame swap for the 55-59 trucks? all these s10 swaps on the 47-53 trucks has given me ideas,lol
Ed |
Re: frame swap?
Re: frame swap?
i was going to make it a 4wd, already have the stuff to do it, but now i am leaning towards bein on the ground with power steering, and a safe ride unlike the stock straight axle,lol
Re: frame swap?
i would go with the original frame and an aftermarket independent front suspension then. much simpler than trying to rig it up on another frame
Re: frame swap?
Re: frame swap?
I recently sold a '58 Chevy Fleetside that I'd put on a '73 Chevy truck frame. Was a easy swap. Just measure everything twice. Took cab mounts off of '58 frame,drilled holes on '73 frame & bolted cab down with new '58 cab mount hardware kit.
Re: frame swap?
im hoping to pick up another 55 cab GMC cab by next week and im gonna set it up on a 64 chassis, will be an easy swap
Re: frame swap?
thanks for th link, very resourceful, I think I am going to stick with the 4wd conversion
Re: frame swap?
do you still plan on the feame swap and go 4x? what i would is try to find an earlier model with the str8 axles and convert your original frame to 4x which would be easier and you can still add ps to the truck by using GM parts
Re: frame swap?
use the stock 57 frame with 77 chevy pick up front rear axles and transfercase,steering box, and even the 77 transfercase cross members, i have all the stuff to do it now its just finding the time to do it, as it is an outside project, not to mention on a budget.
Ed |
Re: frame swap?
well it sounds like you the important parts covered to get started
Re: frame swap?
That is some good info. I just purchased my 55 stepside 2nd series on sunday and the guy want to sell me a 73 pickup that has just the cab on it, but has all the suspension to use to restore it. I am not sure if it worth it to buy for 150 bucks and swap over or just clip the front. Any suggestions
Re: frame swap?
is the 73 a 4wd or 2wd?
Re: frame swap?
Anybody ever considered a Chevy Colorado frame? At one time I did some quick measurements and if I remember the dimensions were close. I got a cheap subframe so am going that way. With all the problems I have run into I have to wonder if I should have tried a swap instead!
Re: frame swap?
haven't heard of anyone doing that with a colorado. bad part is they are six lugs if I'm not mistaken and up until this year they didn't come with v8's so you would have to fab some motor mounts. but hey, it might work
Re: frame swap?
Thanks |
