Replacement dash lighting with pigtails
Just in case anyone else is like me and is rewiring the gauge cluster due to a ruined circuit board, I found replacement lighting sockets with pigtails (replace the twist lock sockets with terminals on the bottom) here:
http://www.hipoparts.com/bulb-socket...tic-or-rubber/ Took me a while to find these so I'm hoping this will help someone in the future. |
Re: Replacement dash lighting with LED
Has anyone replaced dash lights with LED's in a 72 chev. If so, what LED's were used and what color
Re: Replacement dash lighting with pigtails
Thanks for the link, filed it away in my build spreadsheet and will be doing this very soon. Pics of your work so far?
I'll try to get some up soon. I didn't take before pictures so there isn't a good reference point, but I swapped to LED's that I bought off of ebay and they are great.
I posted the replacement pigtails before I installed them. They will fit in the twist lock holes, but aren't a perfect fit and may require some additional silicone, etc. to secure them. |
I ordered these thinking they were the same ... nope too small for the 5/8" x 3/4" holes in the instrument cluster. Have you ordered any of the ones from hipoparts and can confirm they fit in these holes (bottom two specifically)?
Oopps missed or forgot that, thanks, did you get the rubber or plastic version?
Plastic version. Fairly happy with them other than the slight fit issue.
Ordered the rubber version listed there and the fit is pretty good, almost exact diameter fit but could be a hair snugger. Am confident they will not fall out.
