tranny swap problems *HELP*
i have an 86 Chevy reg cab long box with a th350 tranny in it, im swapping it out for a 91 th700r4. the issue i am having is that the 700r4 has a short tail shaft and the 350 has a long. it is a lengthy process to have them switched out so my thinking was to get a drive shaft from a reg cab sort box truck that's post 88 (short tail tranny) . is my thinking correct ? one other issue is that the 700r4 is an electric speedometer. can i just call my local tranny shop to get all the pieces to switch is to a mechanical ? what do i all need to do so?
thanks !! |
Re: tranny swap problems *HELP*
A 700R4 & a Long tail TH350 are about the same length.
I just swapped my th350, for a 700r4 and used the same drive shaft, it fit fine. I had to re-drill the crossmember holes, but that's it, you shouldn't have to change shafts. I thought the same thing before the swap, but guess I was wrong.
Posted via Mobile Device |
Sorry, just looked at your post again, and noticed it said long bed, don't know if it makes a difference, but mine is a short-wide.
I did the same swap on a short bed, no issue with drives haft. Had to move cross member though.
Only trouble is now I have to find the right speedo gears for the trans because the newer trans is setup for electric speedometer. Also make sure you get your throttle valve cable setup right or you will burn up that trans in no time. |
A long shaft 350 and a 700 R4 are about the same length. I used my stock length driveshaft when I install a 700R4 in my 1974 SWB
That acctually brings me to my next question ! it has an electronic speedo sensor , how do i go about changinging this?
That I can't help you with my 700r4 was the same hook up as the th350. The good thing about this forum is somebody knows how, hopefully they will be kind enough to share the info with you. Good luck with the truck. Hope my info helped you
I had to cut the gear off the ouput shaft of the newer 700r4. There is a clip that holds the plastic gear on the output shaft, you should be able to get it off your 350 trans. Trouble I ran into is the speedo gear housing on my th350 is only about an inch big and the 700r4 is about a inch and a half. |
These two pages can help as well http://www.bowtieoverdrives.com/cata....php?ITEMID=14 and http://www.transmissioncenter.net/sp...n_______va.htm
The second one there has a nice little conversion chart to look at for choosing the drive/driven gears too. |
I had a 4l60e that was no use to me because it was to new for my 86. I put it on Craigslist for sale but put I would trade for.a 700r4, it wasn't five minutes later a guy called with a 700 who had a late 90s model and his 4l60 had just went out and needed one. I never been happier with my 700 r4. Like it way better than the th350, what im trying to say is you never know who has what, you may find a sweet deal. Good luck with it. Posted via Mobile Device |
I did the swap in my LWB and had no issue. You should be able to find everything for around 1000-1200 if you know what you're looking for. That includes the TV cable system and converter. I also just moved my crossmember back and have had no issues. Oh wait, yes I have. I dont fill it up with gas nearly as much.:metal:
