disc brake part numbers needed
I purchased McGaughy's drop spindles for my '68 C/10 and am going to install those and front disc brakes. I have rotors, calipers and brake lines left over from a prior project, but don't have the spindle bearings, seals or brake pads. Does anyone happen to have the part numbers for those items? Also, the rotors I have are Wagner BD60258. I'm pretty sure those are correct, but if someone can confirm, I'd appreciate it. Thanks!
Re: disc brake part numbers needed
All of those parts you listed should be the same as 71-72 that you can get at a parts store. You can always take the spindles with you and dry fit them so you don’t have to make multiple trips.
Good to know. Should be easy then. Thanks!
