Painting a Suburban part two
I’m getting ready to paint the roof on my 70 Suburban. I’ve been using a random orbit sander to remove the paint. I used 80 grit to remove the white and gold paint and now using 150 grit to remove the primer. I’m wire brushing the drip rail. My plan is as follows.
Treat and then paint the inside of the drip rail with POR15 Prime with epoxy primer when the POR15 gets to the topcoat window. Prime with a sanding primer. In another post Martinsr recommends a polyester primer. Slicksand is the name I think. Block sand the roof and paint factory white. Am I missing something? Any comments or problems with the plan? Paul |
Re: Painting a Suburban part two
Might want to look into sealer before applying top coat
I don't know much about por15...but if I had it to bare metal id be putting the epoxy primer to it 1st..
You got 2 choices filler over epoxy or filler over bare metal if you are taking it down to bare metal. Once epoxy is covering everything that can rust, then you can move on to your fill primers. I use slicksand and its nice but unnecessary if you don't need that high of a build, its like sprayable filler (but it will not hurt anything to use it) the epoxy will act as your rust protection. Once you get to high fill primer its time to guide coat and block. This is where the work comes into bodywork. |
Paul |
gotcha...I sandblasted mine cause I wanted a super clean surface in the drip rail
Paul |
A good epoxy primer covered with a good quality high build urethane primer is perfect for this job. |
Paul |
With primer, you get what you pay for, everytime! |
Sub'd for future reference as I will be in the same boat with my '67.
Paul have you decided on what product you are using to seal/fill the gutters? I would like to pull my windshield this summer, recaulk/seam seal my gutters and paint the roof on my Suburban. Pending time and available funding. Thanks! |
For seam sealer I'm going with SEM self leveling seam sealer. I'll let you know how it goes.
Foot stomper, I'm afraid it's too late to change primers now. Almost the entire truck is covered with the Omni. Which of the SPI primers would I apply over the Omni to begin my finish bodywork? Paul |
Paul, SEM self leveling seam sealer is not a good choice for your drip rails if you plan on filling them. Just use a thin coat of a good quality sealer (air dry or 2K product) and prime and paint.
Any urethane high build primer that is expensive will do the job better than the cheap ones. Less shrinkage and easier sanding with finer grits is what the premium primers provide. |
Except some expensive primers can be junk as well, stick with one brand and don't mix and match unless your a pro and know exactly how other products work together. You can reduce epoxy primers and turn them into sealers if you feel the need to seal. Read the tech sheets some primers can be painter over directly.
To be clear, you can mix different branded product layers. It's perfectly acceptable to use different brands of primers and top coats. What should never be done is mix different branded activators with branded primers and top coats. The reason for this is because once the product applied has cured, it is ready. There's lots of brands that recommend staying with same because they want to sell their "system". Reducers can vary in quality, but a good one can be used in all the products on the market, so long as it's a good quality. Lots of crappy reducer out there, so pay for a good one.
I have never seen a lousy expensive primer in all my years in the business, but I have seen lots of junky, cheap primers and crappy spray guns make a mess of nice primer. There's no such thing as good, cheap paint (and primer). |
I had already ordered the SEM self leveling seam sealer for the drip rails prior to your post. The package does say that it is made for drip rails. I'm going to apply it after the epoxy primer is applied and see how it looks. |
2 Attachment(s)
I have to say the SEM self leveling seam sealer laid down very nice. The only screw ups were where the gun hit the plastic to keep the paint dust out of the rest of my garage and when I attempted to level it out with my finger. It says in the instructions you can level it out but it sticks to your finger and makes a mess. I let it fill the gap and find it's own level. Also I started at the center over the windshield and there is a bump where the joint is when I started the other side. At the ends I let it drip down the rear pillar to seal the vertical gap.
Sorry no matter what I do the pictures are rotated! |
Looks good if your taking them with your phone take them with the phone horizontal not vertical
2 Attachment(s)
This help?...
Some tape of the roof panel would have given you a nice edge on that side...
