Difference between big block motor mounts
Whats the difference between the big block motor mounts? Is it a 67-70 thing. And the 71 and 72 ones are the different style. Or is it a 1/2 ton 3/4 ton difference between the two different style big block mount set ups? Thanks. Scott
Re: Difference between big block motor mounts
68-71,72 is by itself but look similar to 73 and up. Check in the FAQ and you will find more info.
Thanks so much for the info!
LockDoc |
