Axle bearings lube?
getting ready to install new axle bearing in my 68 rear end. Do you pack the bearings with grease or just install them dry? thanks, Larry
Re: Axle bearings lube?
both semi float and full float get lube from the pumpkin .
and NEVER install dry . always put a little bit on them to give them a fighting chance to live . |
