Looking to ID a Holley 6R-8026 4bbl "Carb Shop" carb
3 Attachment(s)
Cant seem to nail down exactly what this thing is, I'd like to verify the cfm? It has no choke and mechanical secondary's. I'm building a solid lifter 439ci (.060" over 427) BBC motor with a Clay Smith solid 304 cam, 258 duration @ .050" .615" lift. With a Weiand 7620 single plane intake. I'll post pics directly...Thanks, ;)
Re: Looking to ID a Holley 6R-8026 4bbl "Carb Shop" carb
You can also measure the diameter of the butterflies and get a good idea by comparing them to the size of specific known CFM carbs. I have a Holley book with all the butterfly sizes.
I looked in my Holley book and it seems that with the double pumpers, the 1-11/16" throttle bore is used from 650cfm thru 800cfm. The flow difference is determined by the venturi diameter. A 750 should have a venturi diameter of 1-3/8".
Captain Fab, what holley book do you have that has that info? Looking for a way to ID 850 CFM carbs, as I need one and it seems no one near me know actually what they have and most can't read the #'s
It is the Holley performance catalog from 1998. I have had Holley catalogs prior to this one that had the same info. There is a section towards the rear of the catalog that has all the carb list #'s and all the specs for each one.
interesting, thanks.
