Finally Got the Trim On
3 Attachment(s)
Got a complete lower body molding "kit" from GMCPauls.
Nice quality, packaged very well, arrived in perfect condition. :metal: Getting each one to line up with the others was another deal... :banghead: came out ok though. Glad I went with it, was undecided at first but I think I made the right choice. :D http://67-72chevytrucks.com/vboard/a...id=86370&stc=1 http://67-72chevytrucks.com/vboard/a...id=86371&stc=1 http://67-72chevytrucks.com/vboard/a...id=86372&stc=1 |
Looks very sharp. What was the total $. I've got a lot of dings in the trim on my '72 and I'd like to replace it all someday.
HEY VT, DID U SAY THOSE WERE 33" W/ A 4" LIFT :confused:
Yep,
33x12.5's on 10" alloys w/4" back spacing. 4" all spring lift. Even with this mild lift/tire combo, the "gotta hop in" factor is still there. :p Here's an old post with more pics of it. http://67-72chevytrucks.com/vboard/s...ighlight=green |
Wow- trim looks great! Really brings out that color! Did you use the clips, or the 3M tape?
Diane |
great
night and day difference. I too would like to hear method used to attach and words of wisdom and warnings!!
Black accent goes with roll bar and big tires too. |
Trim/Molding
Thanks for the great comments... :)
Bouncy, the reciept is under something... :confused: but was less than $400 Diane, I used a combination of bolt on clips, push in style and just a couple of the plastic clips w/tape. The thing with the tape ones is the thickness of the tape, meaning they don't hold the molding as tight to the body as the other clips do. When I painted the blazer I opened up all the factory trim holes again, so primarily that was why I used the bolt on clips...basically because I could. ;) cheyenne10, mounting methods as per above. Wisdom/warnings...go slow, be patient. Door trim has a front and back, pay attention to that. If you can, get a helper. My 9yr old daughter was working with me :cool: As long as the body panels are lined up (here's where the doors need to be correct) everything should be ok. I had to "fudge" one hole on the pass. side fender to get it to agree with the door trim. Other than that the install went better than I had anticipated. GMCPauls had answered a post I put up asking about trim quality and provided good info about their's. I would recommend the molding parts they sell, each one was perfect coming out of the wrapper. I did order the metal clips seperatley and was very happy with those also. |
Looks great, I like it with the trim on it, I also like the car seat, mine will have one of those too!!!!! :D
The trim addition look's good.....
The trim looks good
That trim really changes the appearance. Beautiful K5!
