Ot whats a disk set up worth?
I have a stock disk set-up from my 71 chevy. it is complete with rotors calipers and spindles. other then being dirty it is fine never had a problem with it. I was wondering what this might be worth?
Thanks Rat |
I paid $150 for the same set up plus the crossmember, upper and lower A arms, coil springs, brake lines, power booster and master cylinder off a 71 GMC in a junkyard. I then spent $300 on rebuilding it....replaced rotors, calipers, ball joints, tie rods, bushings, etc...... I'd say maybe $100... It will still need to be rebuilt.
I sold a crossmember and all the goodies except the M/C for scrap this summer. I couldn't give it away. Good luck
Because of the weight, shipping kills you on this stuff. I gave away a crossmember with dropped springs, disc brakes, and the power gear box just to get rid of it to someone who might use it. Everything as far as the brakes and suspension had less than 3000 miles on it.
