Wire Harness question? Upgrade?
OK, I've had one good day so far to play with the rig. I did an inspection of behind and under my dash. I found the fuse bank all corroded and wiring harness in such a dissaray that I want to change the whole thing out. Any good suggestions for an upgrade?
THE DIFFERENCE BETWEEN IT AND THE OE EXCEPT IT LOOKS NEWER. ;) YOU CAN TRY PM'N HIM - http://67-72chevytrucks.com/vboard/member.php3?u=8317 HERE IS A COUPLE OF PIC'S OF THE UPGRADE / NEW WIRING ;) |
That looks awsome! Mine will look better though....LOL, NOT!
Wow that is a clean looking wiring job
Buy the Painless wiring harness custom made for these trucks. It isn't cheap, but it is well worth the money and it is straight forward to install.
LUV - yours looks like the stock replacement. Most of the new one's have the blade style fuses. You can get them with additional circuits incase you want to add things like power windows, etc.
Thanks guys, gonna go ahead and order me a new Harness. Those Painless bundles look real nice. I like how they put terminals down the sids of the fuse block.
I've seen and advertisement for a wire harness that has what each wire is for printed the entire length of the wire. They were cheap too. Anyone know what brand that was?
I think the ad was in one of the classic truck magazines - the small ads in the back... It looked like a great idea and I think the price was considerably less than the painless kits.
Bouncy,Painless has that feature on their wires.
Make sure when you rewire that you leave some surprises and halfass some things...
Otherwise in a few years time, the new owner won't be able to ***** about the PO's wiring. BEGIN RANT What in the G*$ DA(# world was the PO of my truck thinking? Splices of splices? Pulling a 12V source from the external voltage regulator? Splicing fusable links? C'mon cloth tape? Duct tape? Jeesus... END RANT I just remembered I need to rewire soon. Thanks for bringing the sensitive subject up. Now I will cry silently to myself in my cube. :D |
You may want to check out this company.
http://www.hotrodwires.com/contact.html They print all the way down the wire and are a lot cheaper than painless. Good customer support on off hours. |
I think that's the company I was talking about.
EZ Wiring is in all the mags. I just installed one of their systems and it has every circuit I could ever want and was half the price of Painless. Also the wires are printed as well. However those plug-ins at the firewall are not available from them. It would definitely be a nice addition.
I'm just in the process of installing the Painless System in my blazer. Since I tore the truck apart after getting it and don't have any reference, the rewiring has been difficult. But if you take your time, and only remove the old wiring as you replace the new wiring, the it shouldn't be a bad swap. All the wires have descriptions, but there are alot of extra wires that you need to decide if you want (ie electric fuel pump, third brake light, cruise control, idiot lights, etc.).
My biggest complaint was that I expected the system to be turnkey, with everything I needed to get it up and running. None of the connectors for the lighting were included. The front lights weren't a big deal, but it was difficult to find the correct adapters for the rear since they need replacement. |
Wow, really? Even with the painless? I went to their site and they said it's real easy to install. Well, that's one strike against them! :banghead: I'm not too worried though. I do this stuff for a living and I have plenty o' time! |
