Front springs in rear?
will it raise it up any if fronts are used in the rear of a coil spring truck?
it's not used for haulin (except @ss) ------------------ 71 Custom/10 lb fleet .040 over 350/th350 good ol 1 wheel peel 3.73 12 bolt 275/60/15 front 31x10.50 rear on GMC Safari wheels #3 Dale Earnhardt will live forever in our hearts and memories "THE WORLD'S GREATEST RACE CAR DRIVER EVER" http://burlinator.freeservers.com/index.html |
Front and rear are different coil shapes as I recall... New springs are not too bad thou.. GMC Paul has them for 100 a pair.. http://www.gmcpaulstruckparts.com
Going to a higher rated spring would raise the truck but at the expense of cushion.. ie you would get a harder ride.. |
The fronts will not work with the rear spring holders. You can go with a heavier spring, I have 3/4 tons on my 1/2 ton and got an inch. Other than that it's going to be air bags or spacers on the frame side.
------------------ 71 basic C-10 350. The only option is the rust.No nothing on it, but thats all about to change. |
