Camaro Seats
Does anyone know if a set of Camaro 93-02 seats will fit a 85 C10.
Thanks Bruce |
they wont be a direct bolt in. i had to make some frames out of square tubing.
I just used a pair of seats out of a 02 hyunda sonata had to make a 4" leg for both inboard fronts
If you had a bench seat before they wont use any of the same mounting holes. The sonata seats I used the back mounting track by the seat belt butted right against it. But dont through the bench seat out I used some of the bench track to make those front inboard brackets.
