My truck's bed seems a bit soft...
2 Attachment(s)
Greetings all,
I noticed today when I was loading a smallblock chev w/TH350 attached and a flathead ford engine for a Model A into my truck that the bed was a little soft. Below shows what I found when I took the time to investigate: :hmm: Incidently, no tools were used to remove the wood from the bed, only my hands... :( |
I'll bet your getting better gas mileage now not hauling all that wood around...LOL
My GMC's old bed looked similar to the last pic when I pulled my wooden bed-liner out. Cept mine used to be a steel floor, lol
that's what my stepside looked like when I bought it.
All in all -- it looks pretty good. New wood ought to fix 'er right up. :)
Hey, look at it this way -- the rainwater will drain well. |
hey at least theres no big time rust back there !!!!
is the a model that the flat head is going in, yours ? |
Only surface rust which will be wire-brushed off and Rust-morted. The Flathead is a spare engine that I need to fix the lifters in that belongs to a customer. Ogier |
Now you have a "show truck" bed. ;)
Maybe I should skip the wood and put some lexan back there instead....
Then I could lower it and put 40 inch wheels on it and call it custom... Um, Maybe not... Ogier |
i would like to see a lexan bed floor done , not on any of my trucks but i think it would be pretty cool on a truck with a detailed frame , but its gotta be the slats with the metal strips not one full piece.
has this been done before ??? |
