Door latch
I have a problem I don't understand. Sometimes my drivers door will not latch tight. It does latch on the safety(?) position. Repeatedly closing it will not get it to close tight. If I pull up on the interior handle and then spin the little gear thingy on the door latch, it will usually close. Sometimes I have to do this several times to get the door to close tight. Then the problem doesn't show up again for a week---month---longer. Anybody know what I need to replace? Thanks in advance. Sometimes I don't know what I'd do without this board. Larry
Sounds like it may be worn. If you find that it is, I have a used set for sale, $20. If you're interested, email me. Maybe a good oiling will fix it.
My latches were totally warn out when I first got my truck. I couldn't lock my doors.
I got a set of new latches from Brothers and replaced them. My passenger side door didn't close well, so I had to shim the lower hinge to get the door to line up right. You may have to do the same amount of shimming to get it to fit. |
Mine does that - but only if my inside latch isn't completely down.
Thank you all for the info. I am going to try another latch I have in my junk box and see if it helps. I may be interested in the good pair you offered. I notice it helps if I push down on the inner handle. Thanks again. Larry
