$6.00 score
I was out at the local boneyard a few weeks ago and ran across a van tilt. Someone had taken the steering wheel. I didn't have the time to pull it out, so I just took the shift lever hoping that would keep someone from taking it. I went back and the whole van had been crushed. Since I was out there I browsed through the Jeeps and came across this item. It fits great and with the van tilt shift lever. Yes I know the horn button says Jeep, but I'll get it taken care of soon.
One question about my truck, it is a Sierra Grande. The glove box door is black with the wood trim, the dash is chrome with the wood trim. Is this normal? Thanks. |
Re: $6.00 score
Did this require any mods? Or did it bolt right up?, Who cares if it says Jeep. That can always be fixed. Looks good, especially once you get a new steering wheel.
Re: $6.00 score
The column is the stock GMC tilt. The steering wheel bolted right up. Uses the same horn assembly under the cap. The Jeep column is about 1/4 inch larger in diameter so it doesn't line up exactly, but for $6.00 it will do.
Re: $6.00 score
