Lower Rad Mount Pad ????????
So i go and a=I get this smokin hot deal on a 4 row, near new shape, not even gonna say what i paid, go to drop it in to the truck and find out the tanks do not fit in the mounting pads how can i switch these 3 row pads to the larger 4 row ones without ruining the rad support(freshly painted in the truck)?
:drama: |
Re: Lower Rad Mount Pad ????????
Hi,
You will have to buy new upper mounts, new rubber inserts and new lower mount cups. Pop out your old rubber coushions out of the lower cup then drill out the rivet. Place the new cups in and screw or rivet in. Place new cushions in and just finish installing in reverse of removal. Hope this helps. Good luck. |
