Whats missing?
The rear end on my panel is suppose to be a 72, the rear metal brake lines are trashed,gotta fix,but the end of the rubber hose has a brass fitting for the two metal lines to screw into,its just hanging there, where is it suppose to mount? Am i missing a bracket?Pics please!Alsp put 4 inch lowering springs on rear, can i cut the panhard bar to fit without buying new one?If so how long does it need to be?
Re: Whats missing?
is there a bracket on the diff housing?
Re: Whats missing?
Weren't 71 and 72's attached to a bolt on the rear cover? Earlier axles had a tab welded to the right tube where the brass T went.
Re: Whats missing?
Not on the housing on that side
