What seats out of newer vehicles can I use?
1. From what make and year vehicle have you used?
2. Which seats were they for(front, 2nd row, 3rd row)? 3. How much modification to fit? 4. Pics? |
Re: What seats out of newer vehicles can I use?
jon6.0.. good thread.. . i would like to hear this input.. too..
hey jon, if you get rid of your seats let me know.
-luis |
I had a post with some pictures a while back on installing seats from a '91. The front buckets need to be raised up on stands or they are to low. The second seat is really easy. I'm not sure how to find old posts. I have some pictures I can repost. Dave
I just found the post. dated 10/27/06 on page 5 below Second row seats. Dave
Where is that post at? Can you give me link?
I put 1999 Tahoe Seats in my Burb. IN the back, I need to put spacers to adjust for the floor. But they fit just fine, and work great.
I have seen Van Conversion seats in Burbs, Tahoe Seats, Silverado Seats. There is a thread here that will show pics. If I can get off my lazy hind end, I will post some of mine. good luck. jeff |
I'm not sure how to give you a link but it is posted under newer 2nd row seats BY TyJ back on 10/27/06. It is back on page 5
Once you find a post you want to link you just copy all the mumbo jumbo in the address line of your browser and paste it here. |
im using 99 tahoe captains chairs in front and a 3500 crew cab rear bench seat. all that needs to be done is drill new holes and reinforce the flor pan where you drill.
2 Attachment(s)
I am using the front seats from a 2004 C-3500 extended cab with the console and all. I wish I had better pictures, but you can look at them anyway. I also am putting the matching 3rd row seat from a 2006 Suburban . The front seats needed to be re-drilled and as noted, need to be reinforced in the mounting points for safety. The rear is going to be little more tricky, but I am going to build mounting boxes that are dropped. that way the are like the factory Suburban set up, and I use the factory striker mounts. Again, these will have to be reinforced to be done right.
Attachment 247215 Attachment 247219 |
i used front seats out of 87 sub and just made mounts, and i am goning to put the floor out of same sub in there for the fold down 2nd row and 3rd row pull out seats plus i got the console out of it,in there two
