What gears with 35in. tires
Maybe someone could help me out. I'm stepping up to 35's from 33's, i'm wondering what gears I should put in. Right now I have 3.07 which is ok on the freeway, gets great mileage. But goin up hills it's a dog. I probably won't do alot of freeway driving anyway. I was thinking 4.11 but someone suggested 4.56 do you think that would be too much? Any help would be appreaciated.
I would go with 4.56 if you aren't going to drive on the freeway.
71GMC;
Try this site and play with the # . http://www.prestage.com/carmath/calc_Gears.asp Bill ------------------ 72 3/4ton Custom Camper BB,400 Dynamax Cermax headers , air,ps,pb,leafsprings tilt,3.54 . 82 chevy silverado sb ,ps,pb pw,pd,air 350/350 Flowmaster 40. Torrance Calif. " If I knew I was going to live this long I would have taken better care of myself " |
All depends on how much abuse you're gonna put it thru. For highways and slight mudding adventures I've been well pleased with the 3.73's in my blazer. I've got 33's on it now and plan on 35's when I put the 4" lift on next year. My blazer is mainly just for pleasure riding. Just my opinion, but with that big of tire you can tear some stuff up quick without big gears(4.10-4.56) if you do much offroading.
Matthew |
IMO, 3.73 would be ultimate all around useage gears with taller tires like that, I wouldnt be afraid to cruise the freeway with 4.10's with those tires either, as long as is 2800 or less RPM.
randysringandpinion.com has an rpm calculator to play around with: http://www.randysringandpinion.com/calc-rpm.html click on engine RPM to the right ------------------ Randy- Lincoln, IL r68c30@hotmail.com 2177353230 -71 C-10 350/CH465/3.07, assemble it, yeah right, that'll happen in this world,(not) -84 Z28 Camaro 5.0L 700R4, 3.73, beater, paid way too much for it like an idiot,, -84 Firebird SE 2.8L T-5, rod knocking, dammit,, -82 Firebird 350 4bolt (TBL)/TH350, not running, dammit... buy/sell/hoard/trade most any GM vehicle parts of any kind -parting out: '81 Cutlass Supreme Brougham *Paint is overrated © RSS Enterprises 2000 |
what trans do you have? what engine? if i would drive it alot on highways and such id go 4:10, if you plan for bigger tires later on and mainly want it for around town and offroad id get 4:56
------------------ My Truck pictures www.xframeimpala.com 68 4x4 short fleetside 327 CH465 edelbrock intake and carb MSD distributor its the "SHAGROLET" 56 big window short stepside 235 dual 1 brls 64ImpalaSS 327 70 C10 LWB fleetside custom/10 350/TH350 IM me on aol SN= SHAGROLET |
here is a page with a chart that should help out you gear decision. my 4" lift with 35's is going to be running 4.10 mostly camper towing duty.
http://www.4lo.com/calc/geartable.htm ------------------ 72 3/4 ton 4x4 suburban 71 1/2 ton 4x4 suburban 69 1/2 ton 2wd suburban 79 Camaro RS black & white 92 GMC suburban 4x4 All in Webster City, IA |
I have 35" tires and 3:73 gears. It drives great on the highway, about 2600rpm's at 70 mph. but I wish I had gone with 4:10 gears for a little more grunt off the line.
------------------ 1972 3/4T 402/auto 60k original miles, original paint 1971 1/2t 4x4 frame restored, original paint body put back on it 1968 1ton dually CST 52k original mile, restored 1972 1ton dually cheyenne flatbed, scrap hauler 1972 blazer,rust free, original paint, next project 72 2wd blazer for the above rust free body 1972 3/4t 4x4 GMC, For sale 1968 1/2t 4x4, For sale 72 2wd jimmy, for sale 1969 camaro ss396 4-speed, restored stock Other67-72 parts trucks Lots of parts for sale 2002 GMC 2500HD crew cab 4x4 diesel, I have to have something to drive to work everyday Independence, MO |
I've had 3.73's adn 4.11's with 35's and I think u will want the 4.11's. If you ever go to 38's you will need 4.56's.
------------------ 67 stepside 4x4 Owensville MO mudder67@hotmail.com |
I've got 4-11's with 36" tires and a Turbo 350. It's a good combo. I run around 2800 at 70. I'm putting in 5.13's, in a while, for a little more pull off the line. If you have a 4 spd. manual then 3.73 are good. My 71 with 35's, 3.73's and a 4 spd. manual, runs about the same, going down the freeway
------------------ MOUNT VERNON, WASH. STATE GOT MY BASES COVERED -Big and bad 70 CST Blazer -71 K5 Blazer, 350, 4spd, 2" lift, 35" BFG mudders, Camo, -Work in progress 72 SWB -72 Cheyenne, lwb, 1/2 ton, 4x4, V8, 4spd. -71, 3/4 ton, 402/400, Custom Camper -69, 2wd, ST6, auto, ghetto lowered, 3/4 ton, LWB, "BOMBER" -69 Chev. short narrow 4x4 -69 Chev., lwb, utility trailer, 35" tires, Add or Delete Daily |
All trannies and transfer cases have different ratios so it all really depends what you have and what you want.
Well to answer a few of the questions, I have a th350 and I believe a 350 with a mild cam. Eventually I want to build a motor for a little more power and alot more torque maybe a 383. Most of my driving will be around town and in the hills, not much freeway.I don't think I will ever run 38's, probably 36's would be the biggest I would go. Thanks everyone for your help.
i have 4.10s with 33 in tires and i love it
in my opinion any thing less than 4.10s would prabably be hard on the auto tranny. with 4.10s at 3000rpm you'd be going 77mph with 4.56s at 3000rpm you'd be going 69mph got that form this sight http://www.smokemup.com/utilities/calc/mph_range2.cfm |
I thought 4.10 were a tad too much for the 33's but they are perfect IMO for the 35's. My truck cruises 2500 rpm at 65 with 35" BFG and SM465.
------------------ 70 GMC 3/4 ton Sierra Grande 402/TH400 72 Jimmy 4WD 4spd 4" & 35's 64 Corvette Coupe 68 Camaro 'vert TPI & TH700 69 Z/28 355 12.6's @110 72 Datsun 240Z-ol' reliable |
I think I would choose the 4.56. Even if you do a lot of hiway driving you are only going to be spining a 3000 rpm's at 69MPH!
------------------ 71 SWB Stepside, was a 250, now is a 402 Big Block with 4 speed and 3.73's 72 LWB 4x4 350 4-speed 3.08's posi wearing army olive drab green (SOLD!) 68 BURB 50TH LOOKALIKE with built 350 4-speed 4.11's and posi |
With 35s, I would use 4.10s if you don't have an overdrive trans. If you do have overdrive, use 4.56s.
------------------ Tim |
you guys with 33's, did you have to put a slight lift on to get them to fit? would like to put as much tire on as possible without any rubbing in the wheel well.
thanks. ------------------ 1970 GMC 1500 Custom. 307 V8. Positrac. Brandon, Mississippi. |
My old '72 K-5 had 35's and 3.73. It was kind of a dog. My '69 K-5 had 4.10's with the 35's. I has much more get-up-and-go! I'd run with 4.10's if I were you.
------------------ '69 K-5 Blazer - 350/TH350, 6" lift, 35" tires Bothell, WA |
I run 35's with a TH350 and 4.11's. Not a bad combo. I have to run a lot on the hwy to get to the trails. If I had less hwy travel I would have gone 4.56. My bud has 4.56 and basicly the same set up and it's just winding to much on the hwy. He has a 80 with lock up converter.
When you look at those Gear charts understand that a 3 speed auto without lock up converter is going to run about 250 or so rpm higher to do loss in the converter. If you have a lock up converter then it would be even. If you have Over drive then go for the 4.56 for sure. BIG TRANNY COOLER is a must. Even with the 4.10 if you get on a long enough slope with anough grade your going to be putting some stress on the tranny. I see a 30 degree increase in temp on this long hill near my house if I try to maintain 70mph. Still stays under 200deg on the tranny but most of the time I'm running 150deg on the tranny. ------------------ Grim-Reaper 70 Pontiac LeMans Sport Convertable worlds longest resto in progress 75 GMC Jimmy 4x4 (Dollar) 79 Chevy Blazer (Her's) 89 Toyota Supra Looking for 71-72 2wd Blazer or Jimmy Project www.coloradok5.com I moderate the 73-91 K5 board http://communities.msn.com/OffroadK5s/_whatsnew.msnw |
71, Remember too, the automatic's troque converter multiplies torque until it is "all in" which means you can run a higher (numeerically lower) gear rtio and have the same performance as a higher gear (numerically lower) at low end. The 4.10 ratio should be aboput right and should provide good bottom end torque as well as decent highway cruise range. My .02 cents worth. Gary
I have some trucks with 4.10 and others with 4.56. All have 35" tires. Both work well. It depends on what you are going to do with the truck. The 4.56s pull a heavy trailer better, but the 4.10s do good also. I used to have a 78 K10 3.73s and 40" tires...now that was a pig. Drove it most of the time in low range....lol
