My build! 71 c10 5.3l/4l60e
just picked up a 2004 tahoe 5.3 with 4l60e only 20k on drivetrain. Im pretty familiar with these motors. i just finished a LS6 swap into my 72 camaro.
Im looking for the pin out/wiring diag for the 2004 tahoe 2wd. it is fly by wire. but ill be changing that. will probably end up flashing a diff year file into pcm. any help would be great! ill add info as i go! thanks |
Re: My build! 71 c10 5.3l/4l60e
This would probably be better off as an attatchment but here it is. Pin# , ckt# and description.
Powertrain Control Module (PCM) C1 Connector Part Information • 12191489 • 80-Way F Micro-Pack 100 Series (BLU) Pin Wire Color Circuit No. Function 1 BLK/WHT 451 Ground 2 LT GRN 1867 12-Volt Reference 3 PNK/BLK 1746 Fuel Injector 3 Control 4 LT GRN/BLK 1745 Fuel Injector 2 Control 5-6 -- -- Not Used 7 GRY 2705 5-Volt Reference 8-10 -- -- Not Used 11 LT BLU 1876 Knock Sensor 2 Signal 12 DK BLU/ WHT 1869 CKP Sensor Signal 13 ORN/BLK 463 Requested Torque Signal (NW7) 14 ORN/BLK 1061 UART Serial Data 15 DK BLU/ WHT 774 UART Serial Data 16 -- -- Not Used 17 DK BLU 1225 Transmission Fluid Pressure Switch Signal B (A/T) 18 RED 1226 Transmission Fluid Pressure Switch Signal C (A/T) 19 PNK 439 Ignition 1 Voltage 20 ORN 440 Battery Positive Voltage 21 YEL/BLK 1868 Low Reference 22 -- -- Not Used 23 BLK 470 Low Reference 24 BLK/WHT 451 Ground 25 TAN 1671 HO2S Low Signal - Bank 2 Sensor 2 26 TAN 1667 HO2S Low Signal - Bank 2 Sensor 1 27 BLK/WHT 451 Ground 28 TAN/WHT 1669 HO2S Low Signal - Bank 1 Sensor 2 29 TAN 1664 HO2S Low Signal - Bank 1 Sensor 1 30 LT GRN 1478 Coolant Level Switch Signal 31 -- -- Not Used 32 BLK/WHT 771 Transmission Range Switch Signal A (A/T) 33 PPL 420 TCC Brake Switch/Cruise Control Release Switch Signal 34 WHT 776 Transmission Range Switch Signal P (A/T) 35 GRY 48 CPP Switch Signal (M/T) 36 BLK 1744 Fuel Injector 1 Control 37 YEL/BLK 846 Fuel Injector 6 Control 38 PNK/WHT 1101 Damping Lift/Dive Signal 39 YEL/BLK 625 Starter Enable Relay Control 40 BLK/WHT 451 Ground 41-42 -- -- Not Used 43 RED/BLK 877 Fuel Injector 7 Control 44 LT BLU/BLK 844 Fuel Injector 4 Control 45 GRY 2700 5-Volt Reference (A/C) 46 GRY 474 5-Volt Reference (EVA) 47 -- -- Not Used 48 GRY 597 5-Volt Reference 49-50 -- -- Not Used 51 DK BLU 496 Knock Sensor 1 Signal 52 -- -- Not Used 53 GRY 720 Low Reference (A/T) 54 ORN/BLK 469 Low Reference 55 -- -- Not Used 56 WHT 1579 Fuel Temperature/Composition Signal (L59) 57 ORN 440 Battery Positive Voltage 58 DK GRN 1049 Class 2 Serial Data 59 YEL 710 Class 2 Serial Data 60 -- -- Not Used 61 PNK/BLK 632 Low Reference 62 -- -- Not Used 63 BLK 2755 Low Reference 64 BLK/WHT 451 Ground 65 PPL 1670 HO2S High Signal - Bank 2 Sensor 2 66 PPL 1666 HO2S High Signal - Bank 2 Sensor 1 67 BLK/WHT 451 Ground 68 PPL/WHT 1668 HO2S High Signal - Bank 1 Sensor 2 69 PPL/WHT 1665 HO2S High Signal - Bank 1 Sensor 1 70 BRN 1174 Oil Level Switch Signal 71 -- -- Not Used 72 YEL 772 Transmission Range Switch Signal B (A/T) 73 BRN/WHT 633 CMP Sensor Signal 74 YEL 410 ECT Sensor Signal 75 PNK 1020 Off/Run/Crank Voltage 76 BLK/WHT 845 Fuel Injector 5 Control 77 DK BLU/ WHT 878 Fuel Injector 8 Control 78 -- -- Not Used 79 WHT 687 3-2 Shift Solenoid Valve Control (M30/M32) 80 BLK 407 Low Reference Powertrain Control Module (PCM) C2 Connector Part Information • 12191488 • 80-Way F Micro-Pack 100 Series (GRN) Pin Wire Color Circuit No. Function 1 BLK/WHT 451 Ground 2 BRN 418 TCC PWM Solenoid Valve Control (A/T) 3 TAN 1465 Fuel Pump Relay Control - Secondary (Dual Tanks) 4 -- -- Not Used 5 TAN/BLK 464 Delivered Torque Signal (NW7) 6 RED/BLK 1228 PC Solenoid Valve High Control (A/T) 7 -- -- Not Used 8 LT BLU/WHT 1229 PC Solenoid Valve Low Control (A/T) 9 DK GRN/ WHT 465 Fuel Pump Relay Control - Primary 10 WHT 121 Engine Speed Signal 11-13 -- -- Not Used 14 RED/BLK 380 A/C Refrigerant Pressure Sensor Signal (A/C) 15 BRN 25 Charge Indicator Control 16-17 -- -- Not Used 18 DK GRN 1433 Clutch Start Switch Signal (M/T) 19 BLK/WHT 1695 Axle Switch Signal (NP2) 20 LT GRN/BLK 822 VSS Low Signal 21 PPL/WHT 821 VSS High Signal 22 RED/BLK 1230 AT ISS High Signal (4WD w/MT1) 23 DK BLU/ WHT 1231 AT ISS Low Signal (4WD w/MT1) 24 -- -- Not Used 25 TAN 472 IAT Sensor Signal 26 PPL 2121 IC 1 Control 27 RED 2127 IC 7 Control 28 LT BLU/WHT 2126 IC 6 Control 29 DK GRN/ WHT 2124 IC 4 Control 30 -- -- Not Used 31 YEL 492 MAF Sensor Signal 32 LT GRN 432 MAP Sensor Signal 33 -- -- Not Used 34 DK GRN/ WHT 428 EVAP Canister Purge Solenoid Control 35-38 -- -- Not Used 39 RED 631 12-Volt Reference 40 BLK/WHT 451 Ground 41 -- -- Not Used 42 TAN/BLK 422 TCC Solenoid Valve Control (M30/M32) 43 DK GRN/ WHT 459 A/C Compressor Clutch Relay Control (A/C) 44 -- -- Not Used 45 WHT 1310 EVAP Canister Vent Solenoid Control (EVA) 46 BRN/WHT 419 MIL Control 47 YEL/BLK 1223 2-3 Shift Solenoid Valve Control (A/T) 48 LT GRN 1222 1-2 Shift Solenoid Valve Control (A/T) 49 YEL/BLK 1827 Vehicle Speed Signal 50 DK GRN/ WHT 817 Vehicle Speed Signal 51 YEL/BLK 1227 TFT Sensor Signal (A/T) 52 BRN 2391 HO2S Heater Low Control Bank 1 Sensor 2 53 RED/WHT 3223 HO2S Heater Low Control Bank 2 Sensor 2 54 PPL/WHT 1589 Fuel Level Sensor Signal - Primary 55-56 -- -- Not Used 57 BLK 552 Low Reference 58 TAN/WHT 332 Oil Pressure Sensor Signal 59 PPL 806 Crank Voltage 60 BRN 2129 Low Reference 61 BRN/WHT 2130 Low Reference 62 GRY 773 Transmission Range Switch Signal C (A/T) 63 PNK 1224 Transmission Fluid Pressure Switch Signal A (A/T) 64 DK GRN 890 Fuel Tank Pressure Sensor Signal (EVA) 65 -- -- Not Used 66 PPL/WHT 2128 IC 8 Control 67 RED/WHT 2122 IC 2 Control 68 DK GRN 2125 IC 5 Control 69 LT BLU 2123 IC 3 Control 70-71 -- -- Not Used 72 BLK/WHT 3113 HO2S Heater Low Control Bank 1 Sensor 1 73 DK BLU 1936 Fuel Level Sensor Signal - Secondary 74 LT GRN 3212 HO2S Heater Low Control Bank 2 Sensor 1 75 GRY 23 Generator Field Duty Cycle Signal 76-79 -- -- Not Used 80 BLK 2751 Low Reference (A/C) |
Thank you!!!
Wanted to give a lil update. havnt started the swap yet. but did a few other upgrades. Lowered the truck 2 inchs, installed a front sway bar i got at pick n pull for $20, installed new sway bar bushing and hitch from ece. installed new side marker lights and repaint the front emblems. also picked up a 2000 tahoe back seat for $80. added power brakes from a 3/4 ton that i picked up from hot august nights swap meet for $5! and took the tach out of my 72 camaro factory cluster and added it to my truck!
Few pics..... http://i2.photobucket.com/albums/y18...o/HPIM2147.jpg http://i2.photobucket.com/albums/y18...o/HPIM2149.jpg http://i2.photobucket.com/albums/y18...o/HPIM2151.jpg http://i2.photobucket.com/albums/y18...o/HPIM2144.jpg http://i2.photobucket.com/albums/y18...o/HPIM2125.jpg http://i2.photobucket.com/albums/y18...o/HPIM2127.jpg http://i2.photobucket.com/albums/y18...o/HPIM2073.jpg |
I'm putting a 05 5.3L in my truck too. I'm going to use the fly by wire. I already got the gas pedal and TAC module. The intake, throttle body, injectors, wire harness, and ECM are in the mail and I'm picking up the longblock this weekend.
Here is a link to my thread on LS1tech that has a wiring diagram of an express van....it uses a cable actuated TB. http://www.ls1tech.com/forums/showthread.php?t=781682 |
i wish i would have known you were looking for stuff!!!! im not using the throttle body, fuel rail, or the 5.3 intake!!! :(
im goin cable tb, 6.0 intake.... since it has the bolt holes for the throttle cable bracket, and the 6.0 fuel rail because it has the regulator and return line!! |
