stroked 67 in the future!!
It all started out with me finding a 67 c-10 for 500 bucks with a rought passenger fender and a couple small dents. I took her home and got the 283, 3-speed running by replacing the coil with help from some people on here. but the 283 knocks pretty bad so i found a parts truck from the same guy io bought the 67 from. it has a 350 but has been sitting for a while and could use a rebuild. so i was gonna get a rebuild kit with rings gaskets ect... depending on the shape of the 350 when I take it apart. I found rebuild kits that i think i will need and the run just under 400 bucks i believe, but while i was searching for rebuild kits i found a stroker kit up to 400 horse for just 50 bucks more than the rebuild kit. so i figured what the hell.
Re: stroked 67 in the future!!
It is gonna be fun. i am thinkin going with buddy buckets and getting the disc brake conversion kits that i found on this site for 375 bucks, which is a great price. I will try and get pics of it soon and if anyone has done a stroker kit any advice would be great!!!!!!!!!!:metal:
Where did you find a stroker kit for $450? Did it include the flexplate? How about a front balancer?
Not truck related, but what kind of OLDS? Mine is a "74 Omega. |
I have a 1970 delta 88 2dr. with the 455
and i could be wrong but i think it was $400 on www.rpmmachine.com |
RPM Machine » Product » Economy 355 Chevrolet-Dome Piston-up to ...
Economy 355 Chevrolet-Dome Piston-up to 400HP Product Overview 355 Chevrolet Stroker Kit: Street Kit up to 400 HP Block: Stock 350 chevrolet or aftermarket block 4.030 bore Kit specifications and standard components: Pistons: Economy t-5 heat treated h-series, flat top piston Connecting Rods: Scat 5.700 I beam 3/8 cap screw rod bolt, pressed pin Crankshaft: Scat 9000 series 3.480 stroke 350 main 2.100 rod journal Product Details Stroker Kit Piston Combinations Claimer Piston Compression Ratio 58cc 64cc 70cc Dome/ Dish Volume Flat Top 11.2 10.4 9.1 Call Dish Piston n/a n/a n/a n/a Dome 12.7 11.6 10.1 Call Stroker Kit Options Kit "A" Includes Crank Rods and Pistons Kit "B" Includes Crank, Rods, Pistons, Bearings and Rings Kit"C" Includes Crank, Rods, Pistons, Bearings, Rings, and Balancing, (Bi- internal Be-external) External Balance Assemblies Include Damper and Flexplate SKU#: 1-92305-1 Our Price: $475.00 |
Add bearings and rings for $70
Add balancing to kit $175 See what i mean what a good deal |
I can't help much with the stroker kit but I noticed you were from the big city of Stratford and just wanted to say hi from Brookings.
nice to know there is more guys from SD on here
It is a good price. A total of $624.00 plus shipping to get all the stroker parts.
Summit has a kit that is Internally ballanced for $825 -- http://store.summitracing.com/partde...k=&rsview=sku& looks good anyway. P.S. My Omega is only a lowly 350 Gold Rocket... for now ;) |
