Tilt Column Accessories
Will the chrome accessories for the 67-72 pickup columns fit the 70's van columns or do you have to buy can column parts? If so where?
Re: Tilt Column Accessories
They fit on the van tilts that I had.
Thanks for the help.
Some people prefer the van tilt shifter, as it's quite a bit shorter than the truck shifter.
But the indicator parts should work, correct?
I have no idea, someone will chime in.
yep, the parts for the perndl on a van are the same as a truck. *but the non tolt parts will not work*
I had to shorten my truck tilt lever, as the thread was twice as long as a van tilt and had binding in the column. Easy job though. Everything else was bolt-on.
