desktop dyno
Hey, could I get somebody to do a desktop dyno on this engine with a few different cams.
The engine: -350(3970010 block) bored 30 over, 2 bolt main - 3973487 heads(74.47 cc, 1.94/1.5 valves) with typical porting -balanced and blueprinted -10:1 flat tops -Edelbrock performer intake -HEI swapped from newer SBC -Q-jet carb from a 1979 350 -Hedman small tube headers ->2" exhaust through glasspacks The two cam I would like to be dynoed are: -comp magnum series 280H (230 degress intake and exhaust, .480 lift intake and exhaust) -crane powermax (228 degrees intake and exhaust, .480 lift intake and exhaust) This desktop dyno sounds like it would be pretty cool to have - I think I will have to put it on my christmas list. |
The numbers for the 280H are 326bhp@5000rpm, and 380ft lbs@4000rpm, And I don't have the exact file for the other cam, but what I got from your numbers on it are a little lower than the first one. 329bhp@5000, and 376ft lbs@4000rpm
Thats right around where I thought it would be.
Thanks! |
