oil accumulator
Is any body running a oil accumulator on a bbc i just pick on up and wondering were i should tie it in i was looking at the oil press line that comes off by the filter
Re: oil accumulator
ya we have one, have it plumbed into the lower portion of the block.I removed one of the plugs , right near the front of the block. sorry i don't think i have any pics..
Re: oil accumulator
I use one its a 1 1/2 qt . Its plumbed in above the oil filter . I just had a line made and used a fitting that I could tap off of for my oil press guage . I would recommend a 3 qt one though . I broke a stock oil pump one time and lost the rod bearings and bent the crank . An extra 1 1/2 qts would have saved it .
Re: oil accumulator
do u leave it on all the time or only on start up
Re: oil accumulator
They tell you not to but I do . I do have a Titan pump and run synthetic oil though . Just baby it when you start it like you should anyway .
Re: oil accumulator
thanks now i was reading and it said to put 2 quart in accumulator do u run 6 quart in motor and 2 in accumulator or run 4 quart in motor and 2 in accumulator
Re: oil accumulator
The accumulator is (extra oil)....You will have to add 2qts to your normal oil capacity .
Re: oil accumulator
thanks
