results from the track last night
first pass= all motor
14.3 with a 2.0 60' at 90mph. hooked so hard the truck almost died,just ran outta nuts up top. 2nd pass= 200 shot 12.1 with a 1.7 60' at 106 mph didnt grab the unit until like 20ft out.so i figured id do it sooner the next time and up the pills 3rd pass=200 shot outta the hole 12.3 with a 2.0 60' at 106mph spun as the track prep got worse throughout the night 4th pass= 250 shot 12.2 with 2.0 60' at 109mph spun its a$$ off but pulled harder than ive ever felt overall great night at the track,met a fellow board member. proof of the budget build.he seen the junkyard monster |
Re: results from the track last night
that's pretty darn quick!
i was impressed for what the motor is.on motor its nothing special.but on bottle.the damn thing wont die.with all the bottle im showing it,it shoulda left the rods at the track.i need to do my susp. ive got the stuff laying around just busy to put it on.
are you running a stock rotating assembly?
Nice times btw. |
thanks, ya,kinda. i was at the local junkyard,pulled a engine and took it home.ripped the heads off.its a stock crank and rods but it had hypereutectic speed pros. |
Nice job Couch.. Nate and I were talking a little about you the other day. I have a couple of changes I am doing to my trucks suspension. I'll post some stuff when I get it done. I think it might help you too :)
Also, I was looking at the front of my truck with no bumper. I am going to be adding a little bit of sheetmetal under the grill area to the cross member. I think you and I might be trapping a lot of air there and might pick up form that change. I know running a small piece like that on a 4rth gen F-body actually helps. |
thanks.i strongly agree with the trapped air deal.any direction you could steer me with suspension would be greatly appreciated. i was considering getting it 4 corner weighed and hitting you up with the facts cause you seem to know your stuff pretty well. i wanna do moroso trick fronts and get some travel in the rear. it hooks fairly well until it slams bumpstops and then unloads the rear.
So the rear is squating, hitting the bumps? If that's the case, build some adjustable lower brackets like I did and move that ICG point up to gain antisquat vs squat at the track.
Really all I need is front weight to try and help you on the front spring. So if you have a local scale, weigh the front with you in it. When is the big block going in? Are you wanting a spring that will take that in to consideration (riding front high for a while). |
the rear is squating. but it sits like only an inch from the stops. i will see what i can do about getting it weighed soon. the big block is going into another truck. once i get it all together the nitrous is coming off the small block truck so i can finally have a daily driver that i dont beat up daily.lol.
they make roll pans for the front of Couch's truck.
I can't believe you are spraying that much on hyper pistons! Good Luck is all I can say! |
250 shot on a realtively stock block and hyper pistons and it lived? ...WOW! lol :)
great runs there man!! Good luck with your project! Mike |
we trailered it to the track with the intention of blowing it up.but the d@mn engine wont die.lol. it should be dead by now.it does however have a tits a$$ nitrous tune that i think is a big part of it staying alive,that and race gas and timing pulled out.
as far as the roll pan goes. ive looked into them.theres just something about how they look thats not appealing to me.Dj congrats with the pass time run.cant wait to see it. |
I'm not wild about the roll pan look either that's why I have a chrome bumper with a glass nose!
ya i hear ya on that. i would love to go that route i just cant afford it right now
There is always the chrome plating that guys do on glass. That might be some weight for you Dj..
lol.ya its tuned fat and safe,that and i never show it more then 6k rpm. its had over 30 bottles ran through it lol.the d@mn thing just keeps on tickin
Be careful too fat is worse than too lean! You can lift the ring land off the piston!
Being I will be running on the street I do plan to make a "tube bumper" much like the ones used on the "gassers" of days gone by.... also prefer "stepsides" ..... "different strokes for different folks".... but in the end "love 'em all".... |
Thos glass fronts must shave a ton of weight. I pulled my hood off today then unbolted the front as one piece. My buddy helped me lift it off and the front came up about 2". Wish I had a way to weigh it as a full unit.
yeah, i hear ya on that note. maybe on my BBC truck will i do the fiber front end, but not on my daily driver.that and right now i cant afford it.
If I didn't already have the glass I would still be steel. I wish I knew someone that did acid dipping to reduce weight of the steel parts.
3 inch drop currently and with the fiberglass frontend on it it looks like it isn't even lowered. Got the frontend (US Bodyworks.... their customer service SUCKS!!! ) & a performance truckarm rear suspension setup from another member of the Chevy Trucks Forum (check it out @: http://www.hotrodstohell.net/truckar...uckarm_c10.htm ) I am still in the "parts collecting" stage & little by little I'm buying up what I need to build a kick a** like the ones I see listed on the pages of this forum's race section. |
