'72 Blazer weight per corner
I had posted this in the suspension forum, but maybe this will get more traffic here...........
Anybody know how much a 4x4 Blazer weighs at each wheel with a 350/350/205? Or even front to rear would help. I need this info to get an idea of spring rates for my coilovers. Thanks. |
Re: '72 Blazer weight per corner
I just weighed mine the other day - all stock, 350/350/205, with double wall top on, and spare tire. It was 4850# total with me in it (I am 195). I believe the back was around 2350 with the front at 2500. Hope this helps.
I know my 42" TSL's w/wheels weigh 175lbs each corner. :D
J/K, good info to know. I'll give ya a shout when I do my rear 4-link to find out what you came up with. How's your progress coming? |
Looking forward to see em, is there a build thread? |
No build thread, but I will post pics here if you are interested. Not much to see yet, just a cage, an engine cage and some radius arms with the brackets.
I will post a build thread somewhere. I will post a link here when its done.
OK, I posted a build thread in the projects and builds section labeled "not your typical Blazer build" CLICK HERE
Thank you!! ;)
Everyone really needs to go check that thread out, very nice.
OK, the tag on the door jamb show a GVW of 5850 with the front at 3000 and the rear at 3000. What the heck does this mean? These numbers are quite a bit higher then Hoffa's. I know this is loaded up, but 1000 lbs worth?.........
At first blush, 1000# doesn't seem that much to me. It equals 1/2 ton too which makes sense for a 1/2 ton vehicle. My 4850# was only with me in it and I can't remember if the tank was full or not. Assuming it was, if you throw three 200# guys in there with you, that leaves 400# for cargo, tonge weight, etc.
As for the multiple numbers on the VIN tag, the entire vehicle (sum of the front and back axle) cannot be over 5850# total, and neither axle can be loaded over 3000#. I am not sure about the "maximum capacity" numbers other then what I read on my VIN tag. There is a note that refers to having proper equipment, etc. and that would allow you 300# additional on the front axle. Hope this helps. |
Next time someone asks about roll cage design, we have another great design to direct them to review! Thanks for posting all the pics and info in the build thread. :metal: |
If I type in the weight per corner based off of your numbers, my dual spring weight seems low to me at around 170 over 400. But I dont have anything to reference. I will try springs close to these numbers then adjust accordingly. Thanks for the responses. |
