post latest 1/4 and 1/8 mile times and 60ft.
I haven't been to the track in a while, waiting until i get on a chassis dyno and thinking i'm going to change over to e85. Anyway Post you're best times so far this year.
11.37 at 115.81 7.18 1/8 mile 1.58 60ft. |
Re: post latest 1/4 and 1/8 mile times and 60ft.
12.12 @ 106.34 1/4
7.64 @89.43 1/8 1.77 60ft |
1.32
6.02 @ 116.7 9.45 @ 141.4 |
Updated 7/16/08
How is this for a "67-72 Trucks ET list" http://73-ls1.com/67trucksetlist/67_...ET_7_16_08.JPG Sortable Excel Version http://73-ls1.com/67trucksetlist/67_...t_7_16_08.xlsx If you can provide this info, I will try and stay on top of it at least once a week if not more. Name Date 60' 330' 1/8 ET 1/8 MPH 1000' 1/4 ET 1/4 MPH Year Weight Engine Platform (Cubic inches and SBC, BBC, BBF, LS-series, Hemi) Transmission Stall converter Power adder 1 Power adder 2 Power adder 3 Rear Gear Rear Tire Comments Either way mine is: 1.669 7.114 @ 96.178 11.282 @ 115.322 |
So far, I have this.....
1.49 60' 6.80 @ 99 MPH 10.87 @ 122 MPH Going to try out the new 468 motor this weekend :metal: |
Just changed short blocks and haven't been to the track with the truck in a while (too busy playing with the car and Camino) But don't expect the change to a lighter better rotator to make any significant changes,,,,, 12.03 @ 107,. Typically mid 1.6 sixty's but have seen a couple of 1.60's on a good tight track, with a n/a pump gas small block.
7.27 @ 94 with a 1.55 60' in the 1/8. No quarter mile tracks close to me, so 1/8 mi. is all I've ran. This was ran on pump gas w/o n2o.
8.93 @ 151.00
5.71 @ 123.00 only a 1.32 60ft 10.90 @ 149.00 in s/st I'm hoping to better this after I freshen the motor and change the cam . |
7.35 @93mph
1.67 60ft |
Updated 7/14/08...
Now, I know there are more trucks that belong on this list.. DJ??? |
mine are in my sig. These were run on pass time and should air any day now! The episodes from montgomery started airing tonight!
Kevin, to help me out and not have to go through 30 pages on your truck :) can you give me some of the bullit points on you combo..
hey shaun. on my slow turd its a 69 not 67. but its all good cause everyone thinks it is a 67 cause its got the 67 front end.so i guess you can call it either, but its a 350 stock bottom end, TH-350, 3,000 stall, N20 adder, 4.10 rear gear, with a 325/50r15 MT street DR. comment=daily driven
old combo since I blew it up and will be moving towards a much larger motor! 14 to 1 60 over 454 with Brodix aluminum heads. Dominator, Speedtech plate with 250 jets in it. Glide with ultra bell, ultra case and 1.80 straight cut gear set. Trailing arm rear with coilovers and an anti roll bar! 9 inch Ford rear with 4.30 pro gears. 35 spline gun drilled moser axles and a spool. Kevin P.S. We are gonna add almost 100 cubic inches to this combo. |
Sounds like a 555 or 565 is in your future . That oughta fly !
565
I've been eying this up, thinking next summer or fall maybe. Run N/A on pump gas for bracket racing, and leave my N2O on for fun.
http://www.ultrastreet.net/engines/632_classic.asp |
newbie 6.81 1/8 @ 91.88
1.43 60ft first and only pass hit 3rd lost traction |
WELCOME to the zoo that's pretty quick. |
Ok.. Updated with DJ's stuff and Raddracintrk..
I split the sheet so the there are 1/8 times and 1/4 times. I did this as some have only made 1/8 passes and I don't want to take away from how fast their trucks are moving setting them at the bottom of a 1/4 mile list. Couch, sorry.. I forgot to add your additional info. I added it to the sheet and it will be on the next update. |
Well I was hoping to have a better time for you to post up with my new setup, but a major head wind was effecting everyones times untill the evening when it cooled off and the wind died causing alot of breakouts, unfortunately I was in the trailer by then.
last years best was a 10.77 @124mph with a 1.56 60'. I have ran 1.53 60's but was bracket racing and had to let off so I didn't breakout, pretty sure I would have been in the high 10.6's that Sat. Old setup when the run was made: 489 BBC 150 shot 4128lbs. without driver Turbo 350 4500 stall 4.10 gears 29x14.5 tire New changes: 4003lbs. without driver 4.30 gear 31x16.5 tire |
I wish I could lose 120 lbs. I am on a diet but I can't lose that much I'd weigh less than 100 lbs.
DJ what's your truck weigh?
3222 with me in it!
