5.3 or 6.0 in my 1970?
Hello,
I am going to remove the 283 that is in my 1970 and i want to put in a 5.3 or a 6.0L engine. Can you get decent HP out of a 5.3? Also, are either of these a hastle to install in my 70? Will they even fit? I have the option of a 5.3 or a 6.0, both drive by wire out of a 2007 suv. If i go with the 5.3 can i install a 4l80e on it, or are those transmissions only for the 6.0? I have read some 5.7LS1 threads, but i dont know if they apply to my build. Lots of questions, i know, thanks. Rigo Anybody from Roswell, NM? Trying to find like intrests in my area? |
Re: 5.3 or 6.0 in my 1970?
You should install either :) Several companies make adapters to install these engines. I made my own....not tough at all.
The 6.0L will be able to make more power, but not that much more really. Both are good, capable engines. The 5.3L are usually A LOT cheaper though, but if you can get a good deal on the 6.0L, go for it. The 5.3L can be bored out to 5.7L and accept stock LS1 pistons too. I did a little research, and according to some of the newer truck guys the 5.3L can make around 370RWHP with all the goodies naturally aspirated. The 6.0L can make over 450RWHP. Both will stand up to boost or nitrous too. The 4L80E will fit behind either engine. It's easiest to use the harness for the 4L80E though (the harness is the same as far as the engine is concerned, but different for the tranny). |
I just spent the last hour reading your build thread and its awesome! I am going to stay on top of your build.
Thanks |
i did the 5.3 in mine. all stock i put down 221 rwhp on the dyno and 285 tq. it runs great, i have my camaro to go fast!!
check the link in my thread..... |
Go with the 6.0.The is no replacement for displacement.
No substitute for cubic inches (except cubic dollars)
3 Attachment(s)
I've got 5.3's in both of my projects (69 Suburban & 67 4 Door CrewCab). As stated above the 5.3's are cheaper. The only donwside other than cost that I've heard about the 6.0's is fuel mileage (and that may not be a concern for you). There are alot of different ways to go with the install and it will require $$$$ and time. If you want to spend less money it will take more time and vice versa. Either way it is not as cheap and easy as throwing a stock motor in there. Do lots of research and come up with the best combination (time/money) for you. The way I chose was not the cheapest, but at this point in my life, time is more valuable. If you have any specific questions let me know. Here's a picture of my 69 SuperBurb and the CrewCab, :D.
You can't beat the stock HP and torque from an uncorked 8.1L running on the proper emissions free calibrations. Plus they are a direct replacement for any small block (or big block) and will accommodate any year of big block header or exhaust manifold. The hard part is finding an 8.1L |
I just finished this swap and would put it up against any stock 5.3L or 6.0L. Even mowing through the gears with a HD truck manual transmission I can attest it is much quicker than my bored and whored 396 in my 68' GMC. |
Picts!! I saw an 8.1 spill its guts due to some forced induction, but I'd guess in rock stock they ought to run like a scalded dog!! They are out there and not too much interest in them as they are :gas hogs" so? |
I work for a spun off division of General Motors that manufacturers stripped chassis for the RV and commercial truck industry and we have well over 150,000 units on the road with the 8100 where they get used pretty hard and routinely pull 24,000 lbs of motor home weight around with very little engine warranty exposure. We puke more 4.8L and 6.0L engines in UPS trucks than we do 8.1L’s in motor homes. Like I said, the 8100 is great for stock HP and torque when properly tuned. Big blocks by nature are not one for the reciprocating mass of high RPM ‘s. Force induction with a stock BB is not a good idea either. But let’s put a STOCK 8.1L next to a stock 6.0L and see who wins the HP and torque contest. You put an 8100 on a MEFI-4 marine engine controller with the proper cal files and you have an absolute animal on your hands....spin them past 5500 RPM and you can expect 8 big dents in your hood. |
That engines are LS1 and you can install a 4l60e or the 4l80, I have a 5.3 on my 2001 sylvy y love the power
i doesn't matter. get whatever is cheapest, 4.8, 5.3, 5.7, 6.0, they're all going to BLOW AWAY your 283 and get great gas mileage.
Well, I never done a swap with one of these motors. I have the 6.0 in my 01 crew. Its an ok motor. It sucks gas like no tomorrow. I have a couple friends that have the 8.1 in the same truck. They get 1 MPG better city and Hwy with the same set up I have. Now my Dad went out and bought a 06 1500 4x4 Crew with a 5.3 it also has 35" tires and stock gears. It gets 4-5 MPG better then my truck and feels like it has more power. Last time we went camping he was pulling approx 6500-7500 lbs and I was pulling 9k lbs. I figured I would run away from him on the mountain with 4.10 gears and the 6.0. It didn't happen. He was right behind me the whole way up the 6% grade.
IMHO 8.1 if your going to tow often then the 5.3 if your going to tow once in awhile or not at all. |
WOW! I am just the opposite. I love my new 6.0, and I would never have another 5.3. I get 17-19 MPG Highway and my dad has never gotten over 18 with his 5.3. I just drug home a 68 BB GMC on My heavy trailer nd the 6.0 never broke a stride, while the 5.3 sometimes goes into 2nd with an empty trailer going over an overpass. My truck is a 1/2 ton/3.73 Iguess with the 4.10 yours must be at least a 3/4 ton. I have heard from a lot of people that the 6.0 gets horrible MPG, but I can live with 17-19 anyday. |
6.0+heads,cam,long tubes=500HP. Need I say more?
I put a 6.0 in my Burb and what HartRod said is correct, gas mileage is not THAT great, still way better than my stock 350, and the Burb is heavy, but I probably could have squeaked an extra 2-4 mpg with a 5.3, and with tuning I bet the power wouldn't be that different, maybe torque while towing or under acceleration
but I might opt for 5.3 I guess is what I'm saying? |
I agree also, the 6.0 mileage isn't that great. If I had it to do over I would've done all the same mods I have to a 5.3 because I think I probly would've gotten better mileage.
I know that I have read and heard great stories about mileage. I have a company truck that is a 2001 1/2 ton extended cab 2wd with a 5.3 and it gets about 15. With the 6.0 in my K/5 I get about 13. Bill |
Guys,
As always, you have given great advise! I am currently waitin go hear on prices for a 5.3 or 6.0. Borardmember 70 RS/SS pointed me in this direction and i am waiting to hear what the prices are going to be. I have to say though, I am probably going to go with the 6.0. I would hate to spend all that time and money to find out that i want more (stock)power (i cant spray it 24/7). Also, I have to PM Nate from Porterbuilt. I need to know if i can use one of these engines with his dropmember set-up. I hope i can. His stuff is off the hook! Guys, i will be starting my project soon and will be on here often. I know i can count on you guys to give great advice and play devils advocate on every and all issues of my build. Thanks for all your honest responses. L8R, RC |
pretty good thread here
http://67-72chevytrucks.com/vboard/s...d.php?t=233302 Sold this one back in the winter, it had a 4.8 that I made a 5.7 using ls1 internals. Lets just say it was a hand full from take off:) |
Before the MEFI-4 engine controller fine tuning. The 8.1L sounds rather strange through exhaust compared to older big blocks due to the 8.1L (and other Gen III small block engines) having an untraditional Chevrolet engine firing order (the poor audio doesn't help either). I need a new video now that the calibrations are more dialed in but need a camera man do to so!
Or lets get really wild: 7L, 427ci, 505hp, 490 ftlb, 6000+ RPM, LS7
Nice sounding truck Dirty Larry |
When I had 33" tires on it. I got 13.8 tops on the highway. I didn't think that was to bad for a big truck. But, when I went to the 35" tires. I don't even want to know. I used to be able to go 4 days on a tank ($85) at the time. Now with the 35's I got about 2.5 days at $107 a tank (at the new and improved gas prices :devil:). Needless to say I don't drive it back and forth to work anymore. BTW its 37mi each way if you want to do the math. |
