Solid motor mounts
Hello all,
I have done some searching and can't seem to find any solid motor mounts for my 65. I have the stock type single bolt towers. Does anyone know of a company that makes them? Thanks for any help |
Re: Solid motor mounts
Where did the plate come from who made it?
I belive I bought that one from Barnett Performance in Atlanta, but Summit or Jegs carries them. Cost about a $100. They come as a big rectangle, but with the timing cover cutout and cutout for the waterpump. You cut it to the shape you want. They actually make them in several styles. I used a mid plate too between the motor and transmission, but I don't think I'd do that without a cage in the truck. I've had several friends run the motor plates only and never had problems.
Tom |
Yea I'm wasn't going to run one between the motor trans but I was wondering about the front plate thanks I'll look it up.
I took the tourch to my stock ones and melted the rubber off of them. and then drilled and tapped some round stock turned a step to fit in the plate for center...... Then welded it all up........ worked slick I tapped it 1/2-13..
Sorry.... I dont have any. I would go out and take a pic but the truck is in storage in inman KS at my father inlaws farm. I moved about a year ago and had to give up my shop........ I have a two car garage here but it is a little small......... I may have to kick the wifes honda out and just bring it home Travis
I looked at mine tonight and i think i understand how you did yours. I may give it a shot tomorrow! Thanks for the help.
a company called prothane is making urethane ones. i got mine from summit for about $80. they're a lot stronger lookin the the factory rubber ones. chris.
i think this is what you may be looking for.. they have others also..
http://www.speedwaymotors.com/p/602,...or-Mounts.html |
speedway motors kits ass |
