Bolt pattern on 69 GMC 3/4 ton 8 Lug
Hello All,
Does anyone know the bolt pattern for a 69 GMC 3/4 ton truck? It has the 8 bolts, but I do not know if it 6.5" or what??? Thanks all, Rick |
Re: Bolt pattern on 69 GMC 3/4 ton 8 Lug
My '72 looks like 8 x 6 1/2".
I can't promise that exactly; I was working by myself with a tape major and a flashlight. But, I'll say I'm damn close. |
Yes, 8 on 6.5"
I have a Dana 60, and mine are 6.5" also.
Back when Detroit figured standardizing was a smart thing all 8-lug pickups used the same lug pattern.
My '69 C-20 is 6.5"
so besides the bolt circle what about the hub hole diametter differences?? Ford to Chevy vica versa??????
One of my rims is off a F@rd and fits O.K.
i've heard that chevy won\t fit ford cause smaller hole for axle hub?????
after I think 1999 ford switched to metric.. (damn they've gone metric on us again) The metric one is like 8 on 80mm or something. Before the cut over, the ford rims bolt on to GM's and visa-versa. They are a little wider than the GM ones if I recall too.
my 69 C2500 has the 6.5. I measured it just last night.
the newer fords wont fit theyre off by a little and chevy and dodge r the same i thinks its 8 x 6.5 and most people agree so i would go with that
New chevy and dodges are the same because they use the same axles. And yes, there's a member here w/ the aluminum PYO's off of a newer chevy, and I've seen another w/ the chrome steelies in the long-step thread.
I've got Chryslers on my 3/4 ton 4X4
Would this be the same on a 65 Chevy C30 1ton 8 lug??
