10 bolt Differential housing
I have found a 1986 pick-up differential with 3.08 gears. I have a 1967 C-10 With a 10 bolt rear end and 3.73 gears. Does anyone know if the carrier, ring gear and pinion from the 1986 fit into the 1967 differential housing?
Re: 10 bolt Differential housing
Ah, no. They are internally they are different, but nothing says you can't swap the entire housing under there.
