Baby it's cold outside
Any help would be greatly apprecated
2002 Blazer 4.3 Flushed radiator today Engine temp is normal,not overheating Have no heat or defrost Fan blowes cold air If I had hair I would pull it |
Re: Baby it's cold outside
Flush the heater core. Probably more than once, its a known issue with S10s.
Back flush the core. Remove the lines from the system. Use a water hose to flush it really good.
Does it blow air? Check the vacuum line under the hood. The line connects to the vacuum ball. |
Thanks all for the input
I flushed for 2 days and it did not help Installed a new heater core and now have heat 10 hr to install.Can't beleive they made it so hard to get at Thanks again for yalls help |
Thats rough. I think I will make flushing mine a regular thing. |
I converted mine to yellow stuff. :metal:
dontcha just love dexcool?
I hope you didnt put a long screw in the hole behind the blower resistor. if so you will be stuck on hot and possibly ruin a door actuator. |
