The official,unofficial guide to transfer case adapters
"What does this adapter fit or what adapter do I need to run transfer case X behind transmission Y" is a commonly asked question on this board and others that I frequent.This is a guide to help identify what parts you have or will need when swapping transmissions and cases.
Starting in around 1970ish until around 1977 the Th350/205 adapters used a center support bearing around the drive sleeve to hold it in place. http://i59.photobucket.com/albums/g3...ale/009-17.jpg The sleeve had a step cut in it to accommodate the bearing,whereas the later style didn't. Early style on the left,later on the right. http://i59.photobucket.com/albums/g3...20pics/008.jpg The 78ish to 80 Th350/Np205 adapters are identical to the earlier style with the exception of the sleeve and bearing.All Th350/205 will have a four bolt pattern on the trans side. http://i59.photobucket.com/albums/g3...20pics/084.jpg And racetrack or figure eight pattern on the case side. http://i59.photobucket.com/albums/g3...20pics/085.jpg During that time GM also offer the 203 fulltime case behind the TH350's and they took a different adapter. Trans side. http://i59.photobucket.com/albums/g3...ics/8c3a_1.jpg Case side. http://i59.photobucket.com/albums/g3...ics/8d51_1.jpg The Th400 adapters came in four different styles depending on the application. The 400/205 adapters were either the figure eight/racetrack pattern up until about 1984,or the later round pattern used until around 91 when the body style changed on the 1-tons. Figure 8/race tack pattern (trans side). http://i59.photobucket.com/albums/g3...ale/005-19.jpg Case side. http://i59.photobucket.com/albums/g3...ale/007-15.jpg The late style round pattern adapter. Trans side. http://i59.photobucket.com/albums/g3...s/100_3345.jpg Case side. http://i59.photobucket.com/albums/g3...s/100_3348.jpg |
Re: The official,unofficial guide to transfer case adapters
The 81ish-87 3/4 ton's with the Th400 trans used a different adapter.It is shorter/thinner than the 400/205 adapter's and has no provisions for a shifter to be bolted on the side.
Trans side. http://i59.photobucket.com/albums/g3...0pics/4002.jpg Case side. http://i59.photobucket.com/albums/g3...20pics/400.jpg The 400/208 combo's used the Mil CUCV pickup's were the same as the civilian versions but use a taller or longer adapter.Otherwise they are the same as the civ version. http://i59.photobucket.com/albums/g3...Picture193.jpg The 400/203's used one style and it was completely different from the others. Trans side. http://i59.photobucket.com/albums/g3.../pics525-1.jpg Case side. http://i59.photobucket.com/albums/g3...s/100_3170.jpg In about 1981 GM starting usin the 208's behind the Th350's.It was only a 1-2 year deal until the 700R4's came out.The 700 and 350's both different adapters. The Th350/208 adapter,trans side. http://i59.photobucket.com/albums/g3...s/100_3172.jpg By 1983 they were using the 700's and it required another adapter. Trans side. http://i59.photobucket.com/albums/g3...e/100_3171.jpg |
The SM465 four speeds used four different adapters.The 465/Rockwell 221 adapter was the first.(I will post at a later date).
The second was the 465/205 adapter used from about 1972ish to 1980. Trans side. http://i59.photobucket.com/albums/g3...cture192-1.jpg Case side.(again the racetrack/figure eight pattern) http://i59.photobucket.com/albums/g3...sale/023-5.jpg Around 1973 until 1975 they offered the 203 behind the 465.This is the only pic I have at this time. http://i59.photobucket.com/albums/g3...s/100_4047.jpg The 3 speed sagianw transmissions were offered with a 205 behind them as well. Trans side. http://i59.photobucket.com/albums/g3...20pics/028.jpg Case side. http://i59.photobucket.com/albums/g3...20pics/019.jpg In 1981 they went to the NP208 and for the most part got away from the 205's except in the 1-tons.The 465 adapters changed again with the case change. Trans side. http://i59.photobucket.com/albums/g3...Picture192.jpg Case side. http://i59.photobucket.com/albums/g3...Picture191.jpg Around 1986 GM went to the round pattern 205's and changed the adapters also. Trans side. http://i59.photobucket.com/albums/g3...ale/007-23.jpg Case side. http://i59.photobucket.com/albums/g3...ale/006-27.jpg The late 465/205 adapter looks alot like the 465/208 adapter but the 208 adapter will work on a 205 due to it not having any provisions for a shifter(notch on the flange and threaded insert on side. http://i59.photobucket.com/albums/g3...ale/005-30.jpg Now for the disclaimer.I am not an expert nor do I claim to be.The dates are not exact,give or take a year or two, and this is not to say that newer/older parts have been swapped in.These are merely my observations from years of swappin/buyin/sellin and usin these parts. |
Good idea! I'd like to add that of the 465/ 205 combos, the later "round pattern" is IMO the best. It uses a female input like the TH400 setup. No coupler to wear, less "clink clank" on accel/ decel and far stronger. The old coupler type can can split or shear the splines off with big HP and abuse.
I have pulled the old 10 spline sleeve's off and the splines on the trans output have almost a razors edge on em.The later is a lot better design,just harder to come by.
Do you need pics of the Rockwell T221 to SM465 adapter? I'll take some good ones for you if you do. I also have a good pic with a side by side comparison of the NP205 sleeve and the Rockwell T221's sleeve.
Here are some I have. #1 is the transmission side of the 465/221 adaptor
http://i14.photobucket.com/albums/a3...y/DSC02983.jpg this is the transfer case side http://i14.photobucket.com/albums/a3...y/DSC02984.jpg the side cover http://i14.photobucket.com/albums/a3...y/DSC02985.jpg and then I had this shot saved of the 32 spline 465/205. This isn't mine, I forget where I found the pic. http://i14.photobucket.com/albums/a3...ny/465_205.jpg |
Lookin`good for a FAQ thread for sure.How about transfer case differences for each transmission?Like spline counts and differences in shaft lengths.
This has been long overdue...some great info here.
Here is a comparison of the measurements of the SM465/Rockwell T221 combo and the SM465/NP205 combo (the NP205 is a 70's vintage with a yoke style rear output.)
http://yukon.b0xen.us/69chevy/rockwellinfo.jpg http://yukon.b0xen.us/69chevy/np205info.jpg And here are some pics of the coupler/sleeve differences. Both couplers are for mating to the SM465. http://yukon.b0xen.us/69chevy/couplers1.jpg http://yukon.b0xen.us/69chevy/couplers2.jpg http://yukon.b0xen.us/69chevy/couplers3.jpg The first pic makes the one coupler's diameter look alot bigger, but it is actually just a bit bigger. And a note, the 3 speed manual/Rockwell coupler is longer than the SM465/Rockwell coupler and can be cut down to be used if you were to swap from the 3 speed manual to the SM465 but still staying with the Rockwell transfer case. |
Thanks for the pics. Quote:
Does anybody have any pics of the TH350/Dana adapter ???? The one used before the 205's.That is the only adapter I have never had one of. |
Excellent information. This will be very helpful in my saginaw to sm465 conversion. Thank-you 1-tonmudder!
I got my late style 465/205 adapter today so I added that info.
Old thread--does anyone know where this information (with pictures) can be found today?
