gauge troubles
A quick question, Can you test/check the plug going to the printed circuit for power. having probs with all gauges, and just wondered if getting the correct juice to each copper connector. trying to go wire by wire, gauge by gauge. All new wiring harness from classic parts, plug and go. I thought. Am adding ground extra ground wire tonight to be sure. Thanks
Gary |
Re: gauge troubles
Electrics are always a tricky issue, are they all not working? or just one or two? are your dash lights working? is the prob intermitent?...could be an earth prob, also are the little copper circuit strips where the plug connects all present and straight and making contact.
Re: gauge troubles
Re: gauge troubles
If you changed your sender unit in thy tank did you make sure it was for your engine size, also on the back of the gas gauge ther are litte white blocks called resistors these usually need changing to a larger size if you got the wrong sender. The temp gauge could just have had it and your oil presure is obviously picking up interferance from your engine I can only sugest an earth prob there, but I may be wrong. Try the search funtion for more help with this as it has been well covered in previous posts, it helped me with my gas gauge problem.
