Need some help finding some 8 lug rallys
Hi Guys, I need some help finding some 8 lug rallys. I have a 2001 chevy 2500 hd 4x4. What I would like is a set of the 73-87 chevy truck rally's in about a 10" wide with the correct back spacing for that year of truck. I do not have a lift kit but wouldn't mind going a little taller and wider than stuck with the tires so if you have a recommendation on that too as far as size too.
Thanks! Dave |
Re: Need some help finding some 8 lug rallys
anybody?
Never seen an 8-lug rally?
Seen a 3/4 ton Suburban with some early 90's Dodge wheels a long time ago that almost looked like rally's. You might be able to have someone like Stockton or Wheel Vintiques make you something but it probably wouldn't be cheap. |
i dont know what ur planning on doing as far as having them made, i will tell you that 6 lug rally's off an 83 bind on the calipers of my half ton...had to shave them... it will probably be worse on your HD...but she will look mean, this is mine after the swap with some 31x10.5 15's, paid 10 bucks a piece for the rims and tires together...some people just dont know what they have with these rims
