What is your engine setup?
Just for kicks what is your engine setup? What size, carb, intake, heads, cam, headers etc. What would you chang if you could?
Re: What is your engine setup?
It's in the sig.
I'd have a 383, and a roller cam. |
383 STROKER, 272H cam, 202 heads, HOLLEY 600, headers, HEI,change??? NOTHING!!!!
406, VICTOR JR.HEADS, JESEL SHAFT ROCKERS,COMP 286 XTREME ROLLER,SPLAYED MAIN CAPS,CRANK SCRAPER AND WINDAGE TRAY,BOWTIE SINGLE PLANE W/REWORKED 750 HOLLEY TO 830,AND PRO SHOT FOGGER. NO CHANGES!:chevy:
406, aluminum heads fully worked, eagle crank, je pistons, worked hp650, victor jr intake, doug thorley headers, roller cam, msd billet dist, msd ignition, taylor 8mm wires there is alot more just cant remember all off the top of my head,, is it fast ??? of yes :lol: change nothing for now...future might include an LS6 either in this truck or my future 67 small window stay tuned...
WOW those are some serious engines I just have a little stock 350 with and Edelbrock 700 and performer intake. I want heads and a mild cam soon though.
Well...
I6 250 (bone stock) |
454BB msd billet dist,msd 8.5mm wires, 750 cfm 4-Barrel Proform Race Series Carburetor,FlowTech Full-Length Ceramic Coated Headers,Meziere Enterprise Electric Water Pump,Holley Blue Electric Fuel Pump to help feed it. Weiand Intake Manifold, Heads well I know knothing about the heads But I would like fully worked aluminum heads in the future. My Cam thats another I know nothing about yet but it sure sounds good..
Change I would like a fully Blown 572 :lol: |
You guys realy have some nice modified engines.
I have a bone stock 350 in my '71 C-10 lwb stepper and a bone stock 250 in my '67 swb stepper. What would I change, I guess clean them up and paint them original colors. Danny |
Another stock 350 here with a Q-jet sitting on an Edelbrock 2101 (stock intake cracked).
About the only things I wish I had done differently would be spend the extra $$ for a 383, and figure out why the vacuum is so low (maybe brake booster?) so I could use my big cam and still have it start & idle when cold. |
I just have a stock 96' LT1 w/bolt-ons
454 (+.040), Holley spreadbore (650?), stock intake, peanut port heads , RV cam, stock manifolds
here's what I'm changing to- the parts are sitting here waiting for me to install! :metal: Holley 870 carb, E'Brock RPM-O Air Gap intake, E'brock RPM-O Aluminum heads (2.25/1.89 valves), Comp Cams 278 Xtreme Energy Cam & Roller Rockers, Hedman Ceramic Coated long tube headers. |
Stock low miles 1989 Roller cam 4bolt 350 shortblock with comp 276 roller cam, unknown history double hump 61cc 2.02 intake old school fully ported heads, full length Headman headers, 2800 stall TCI converter, Painless Delphi based EFI with F&B 6barrel MPI intake. Walbro 255lph fuel pump, Mallory regulator and Fram Fuel filter. 275rwtq, 265rwhp, both at 5000rpm (limited)...Still new to building Chevrolet motors, so Im here to learn!
Bruce |
'88 TBI 454 from a C3500. Stock rebuild aside from the Edelbrock Performer intake, Doug's headers and cam upgrade. Stock computer and everything transplanted into a 1970 Suburban. I'm hoping to fire it up for the first time here in a few weeks. Nothing super spectacular, but I'm looking for 450+ ftlbs of torque down low in the rev range to move the heavy thing (wish I had the moolah for some 60499 heads).
The other is a .030 over 350 w/ Edelbrock aluminum intake, q-jet, RV cam, HEI, Doug's headers and 2.5" dual exhaust w/ Flowmasters. I like it because its loud.:metal: |
455 Buick, waiting to be massaged and shoe horned in.
Mine is supposedly a 300hp 350 from a camaro, running the numbers does seem to support this, truck had a six in it when it left the factory. I'm pretty sure the cam isn't stock, but I don't know what it is, stock intake with a newish Carter AFB four barrel, carter electric fuel pump to match K&N, and a Mallory twin point dizzy. The dizzy and manifold are going to be replaced with an Performer EPS and a stock (used) HEI again from a camaro that I have sitting in the garage waiting to go on. Ramshorns and 2 1/4" duals finishing in front of the rear wheels.
The guys from a local garage that specialises in US trucks and a friend who drag races a 9 second camaro reckon it is pretty quick for a big lump of a truck. I'm hoping the manifold and HEI will perk it up a bit along with a good tune up. Still want to pull it one day, find out whats in it and give it a coat of paintas its pretty scruffy. |
Original '69 350 with correct identification (supposedly rebuilt at some point), with at least 200K miles on it. RV cam, Hooker headers, Edelbrock 2101 intake with Edelbrock Q-Jet and an Accel HEI replacement distributor. Oh, it has "some" oil leakage and "a little" blow-by. But, it still ran great until it was pulled out in September!
What would I like to have in its place? I think a Tri-Power 421 Pontiac would be nice. |
'68 327 + 0.030 over with Keith Black 10:1 hyperneutic pistons, Comp Cam XE280 cam + valve train sitting on factory Vortec heads, Edlebrock Performer intake with a self tuned Q Jet. Flotech headers and Flowmasters. Tremec TKO 600 5 speed with 3.42 posi out back.
The what I would change is what I just completed, cam change from XE252 to XE280 and tranny swap from T-5 to TKO. LOVE IT! Daily driver Step on the loud pedal and listen to the eagles scream . . . |
496 - 4 bolt main, forged everything, roller everything, msd everything, balanced everything, 850 holley dp, massive lift roller cam (over 600 adv.), performer rpm heads, air gap intake, large tube headers, hooked up to a TKO 600 tranny.
the one thing I may change is add at least a 200 shot of nitrous to get this baby over 800hp... |
396 BBC from Speed-O-Motive in my 67 Camaro with 750 Holley 3310, mild cam, 10.25.1 compression, Edelbrock Performer, stock heads, Dynomax headers, Pertronix, runs great. 350 in my 68 C10 with stock cam, Weiand dual plane, 600 Holley 4160, log manifolds, new Procomp HEI, runs smooth and cool.
250 inline
HEI Offy Intake 500 cfm Edelbrock Three on the Tree Thinking of going to a little smaller carb. |
[QUOTE=prostreetC-10;3354706]You little 383/406 guys! lol
BBC all the way! :lol::lol::lol: aaahhhh ok!!! |
stock 350 3310 holley airgap rpm
want to switch to ls1 or blown 427 but I need to finish body work first |
