TH350 SHIFTER installation?
Can I install a B&M shifter after I install my TH350? Is it easy to install after I put the tranny in from the bottom? Anybody install a "Z Gate" shifter with some pictures? It the shifter easy to install?
Re: TH350 SHIFTER installation?
no problem at all. Just make sure the cable does not have any tight turns/bends in it and keep the cable away from exhaust. Chose where you want the shifter to be and make sure it has full movement. Remember that the cable will start out heading towards the front of the truck then curve around and come up behind the pan to the linkage so make sure the cable also has enough length to do this before you bolt the shifter into place
